hks actuator kit
i did a search but it really didnt help, so i need some input. Ive got a s13 black top in my s14 and i am using an apexi avcr boost controller. My car is tuned at 13psi, but it seems in second and third my boost bleeds off down to about 9 or 10 psi a little more than halfway through my power band. Is the hks actuator kit my solution to this problem, and if so does that work with my AVCR?
Man w/ CTSV & a Car Seat
You need to play with your AVC-R. If your setting it by just using the boost psi setup, it wont hold. You have to play with the other setting *duty or load cant remember what its called* Crap id explain it more if i have my car but i dont. I was having the same issue your having till a friend of mine showed me how to set it up. Basically you start off lower on the lower NE points *3k @ around 54-60%* and higher at the higher NE Points *7k at max or close to max of 90%* You have to play with it so its constantly at 13-14 psi *1 bar* without spiking too much. Anything more than 1 bar and your liable to blow your turbo seals. You can run the HKS actuator but you already have an AVC-R, might as well put it to good use.
