Old 02-19-2005, 01:37 PM   #1
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
official conquest/starion wheels thread (56Kamikaze)
okay after much debating i broke down and snagged some starion/conquest rims from the junkyard knowing full well that the rear offsets may be too low. if this belongs in tech just move it, i just figured lots of people might want this info.
alright so we have three different rims here. turbo'd varients supposedly come only with 16x8 and 16x9's (staggered) but the car i found had 7's and 8's like the NA models so this test only involves the 7 and 8 inch wide rims.
the pis speak for themselves.
16x7 on the rear might need a little pulling and at least fender rolling but they fit pretty perfectly flush.
now, maybe the 16x9's would have a better offset (doubt it as they just have a higher offset adding rim to inside the wheel well). unless you add some fender by pulling or aftermarket bolt ons these suckers will look like crap.
this is why i believe the 16x9's just have a higher offset. notice how a TON of rim can still fit back there.
here's a shot of a 7 and 8 side by side
if anybody has anything to add or ask for go for it.
i'm almost certainly gonna sell them but if i did keep em they'd look like this when i was done:
MakotoS13 is offline
Old 02-19-2005, 01:48 PM   #2
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
yea but the starion wheels dont look good at all. save money dude, get good wheels
hydropgrahics!
ls1......
420sx is offline
Old 02-19-2005, 02:02 PM   #3
HyperTek
but your car is stock suspension... drop it.. fole/pull fender via bat... negative camber.. it will look totally different then just rim on a uncompressed suspension..
Keep it Classy
HyperTek is offline
Old 02-19-2005, 02:07 PM   #4
MakotoS13
MakotoS13's Avatar
i guess i won't sell em till i get coilovers and see what they look like when she's dropped. the cost of making them fit and cleaning them up is more than a good set of zigens with perfect offsets that wouldn't require any modification.
80% sure i'm gonna sell em
Old 02-19-2005, 02:29 PM   #5
Ritz S14
Ritz S14's Avatar
Damn.. It doesn't look too bad. Too bad you didn't pull/roll your fenders before you painted your car.
Ritz S14 is offline
Old 02-19-2005, 02:40 PM   #6
Equinox
Equinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enough
Send a message via AIM to Equinox
Just some clarification about the wheels. The earlier starions both turbo and NA came with 16x7 up front and 16x8 out back. The later model starions (88 and 89 i believe) had a factory option which included 16x8 up front and 16x9 out back. Note the offsets on the two 16x8s are not the same. If I recall correctly, the one that will best fit s13s are the FRONT 16x8s off the later models.
-Steve
http://www.controlledspin.com
Equinox is offline
Old 02-19-2005, 02:41 PM   #7
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
Fronts 16x7 +16 some offset
Rear 16x8 -12 some offset
Front 16x8 +16 some offset
Rear 16x9 +/- 0 offset
All tight best would be 16x9s all around
Zemus is offline
Old 02-19-2005, 03:10 PM   #8
sciamop
sciamop's Avatar
sciamop is making a name for him/her selfsciamop is making a name for him/her self
All Starquests were turbocharged. There were different suspension/trim/turbo packages though. Too bad those cars were such hand grenades...
Makato: Since you've done the 5 lug conversion, there should be a plethora of wheels that you can try to fit on your car: MKIII Supra 16x7 (91+ 5 stars) might be a good fit...
GL,
Todd
93 Coupe
91 SE-R
83 Starion (sold for $500 in 1992 -- blown LSD)
sciamop is offline
Old 02-19-2005, 03:28 PM   #9
MakotoS13
MakotoS13's Avatar
yeah i knew it was a long shot but for soemone with the fender in back they'd be perfect. i'm sellin em and stickin with my SE's for now. i just wanted to see how they'd fit and i knew some people wanted the info as well.
after coilovers these are goin on the car:
mmmmm
Old 02-19-2005, 03:31 PM   #10
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
you have ur car jacked up, there is no spring compression like stated above and no camber added which is why the rim looks like it sticks out too much
SilviaDriver is offline
Old 02-19-2005, 03:34 PM   #11
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
having your car in the air with those rims mounted with NO tires is an inaccurate way to measure how the'y'll fit
go throw some cheap used tires on then mount them on the car on the ground...
Heartwork is offline
Old 02-19-2005, 03:53 PM   #12
DRO916
DRO916 is an unknown quantity at this point
Send a message via AIM to DRO916 Send a message via Yahoo to DRO916
heres a pic i took of someones car from last novembers us drift event
DRO916 is offline
Old 02-19-2005, 04:15 PM   #13
MakotoS13
MakotoS13's Avatar
i refuse to believe that setting the car on the ground and lowering is going to bring in a rim almost 2 inches to where it can fit under a stock fender. the 7's will prolly fit really well but i'm selling them all as a set so that's a no go. i guess if no one wants them i'll just have 2 extra 16x8's waiting for the day i get more fender.
Old 02-19-2005, 04:18 PM   #14
Ritz S14
Ritz S14's Avatar
What you could do to make the setup more realistic is to place teh jackstands under the LCA so your suspension is loaded.
Ritz S14 is offline
Old 02-19-2005, 04:22 PM   #15
Heartwork
Heartwork's Avatar
it may not bring it in a whole 2 inches, but it will be way more precise into dialing in how much thick of a spacer, rolled fender, or camber you need...
i.e. do a search for SilviaDriver's post where he put 18x9.5 +22 on like you did. It stuck out literally about 1-1.5" outside the fender....then put tires on and sit it on the ground it fits easily....
Old 02-19-2005, 04:38 PM   #16
SilviaDriver
http://www.zilvia.net/f/showthread.php?t=51899&page=1
there the link. pics are taken down you have to ask 95blue240sx for them.
Old 02-19-2005, 04:44 PM   #17
North240
North240's Avatar
North240 is an unknown quantity at this point
for an "official" thread you would think there might be pics of tires mounted and the car sitting on the ground?
ROUND 2
North240 is offline
Old 02-19-2005, 05:20 PM   #18
MakotoS13
MakotoS13's Avatar
mount some tires on em and have at it chuckles. i only made this post so that people in the future could have something to search for to get an idea of how conquest rims fit on an S13. i'm not mounting tires just for an experiment/the good of others.
i'm already in the process of selling the rims anyhow.
p.s. its official cause i said it is cause i got dibs first.
Old 02-19-2005, 05:22 PM   #19
Johny5
Johny5's Avatar
i'll give you $350 and will come pick them up since you're such a girly man about good fitting wheels doug
www.stewartleask.com
Johny5 is offline
Old 02-21-2005, 10:17 AM   #20
AadosX
AadosX is making a name for him/her selfAadosX is making a name for him/her self
Send a message via AIM to AadosX
If anyone wants a set of these let me know... I have access to GOBS of them.
[email protected]
email only.
AadosX is offline
Old 02-21-2005, 10:53 PM   #21
Marty
Marty's Avatar
Marty is an unknown quantity at this point
i actually think that your idea for painting them black with the silver lip looks quite good
Marty is offline
Old 02-21-2005, 11:19 PM   #22
SimpleSexy180
dude makato they look clean painted black and chrome lip. My homie had those on his ae86.
SimpleSexy180 is offline
Old 02-22-2005, 12:40 AM   #23
stuntman240
stuntman240's Avatar
stuntman240 is an unknown quantity at this point
Send a message via AIM to stuntman240
Fronts: 16x7 +18 spaced out to -9 THEY WONT CLEAR Z BRAKES!!!
Rears: 16x9 +/- 0 no spacer
Tires were 205/55/16 all around.
16x8 -10 is 3mm inset from 16x9's
NO PULL JUST A ROLL
They came in the foloowing sizes:
16x7 +18
16x8 +18
16x8 -10
16x9 0
I have a pair of each but the 16x8 +18
Ill get more pics later.
www.ClubFR.net
stuntman240 is offline
Old 03-22-2005, 01:34 PM   #24
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
do any of the sizes clear Zbrakes? Specifically the 16x8 -18 and the 16x9 +/- 0
rancid240 is offline
Old 03-22-2005, 04:45 PM   #25
raen419
raen419 is an unknown quantity at this point
Send a message via AIM to raen419
i would think the rear wouldn't be an issue.
but offset has nothing to do w/ wheel/brake clearance.
and that's +18, not -18.
raen419 is offline
Old 03-22-2005, 06:17 PM   #26
MakotoS13
MakotoS13's Avatar
it does because spacers can be used to alleviate any such clearance issues thus making the offset of the wheel important in relation to said spacing and in need of appropriate compensation.
Old 03-22-2005, 06:28 PM   #27
sr420det
sr420det is making a name for him/her selfsr420det is making a name for him/her self
those are f***ing ugly
sr420det is offline
Old 03-22-2005, 07:17 PM   #28
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Try and find wheels with a decent offset for 50 bucks then come back and say those are ugly
wootwoot is offline
Old 03-22-2005, 08:11 PM   #29
Grip Gambler
Grip Gambler's Avatar
Grip Gambler is an unknown quantity at this point
Send a message via AIM to Grip Gambler
they are good beater wheels, my friend just got 8 of them for dirt cheap, good to use during 5 lug conversion.
Inside girls club
Grip Gambler is offline
Old 03-23-2005, 12:12 AM   #30
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
My 16x8s -10 on my friends car with 1 degree of camber, it'll be a tough fit on my car, but I run a lot more camber and the car hasnt settled yet.
PROCEED
Grip Gambler
KiDyNomiTe is offline
