Old 03-28-2005, 08:15 PM   #1
mastaflash05
mastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nice
Send a message via AIM to mastaflash05
Which Aeromotive FPR?
im looking into getting an aeromotie FPR and im not sure which model to get. here are the 2 that i think i would need and need to decide between...
1. http://store.summitracing.com/defaul...=egnsearch.asp this one has 2 inlets and i guess one out. i dont think i need 2 inlets so im not sure if this is the one i need. it says it is a return type regulator. does this mean that the fuel goes back into the tank? because i need this.
2. http://store.summitracing.com/defaul...=egnsearch.asp this one is the "compact" one. claimed to support 1000 hp. has one inlet and i guess one outlet. this one says it isnt a return type.
i just need to know which one to get so i can get my fuel system together. incase its needed im going to be running a top feed rail and 72lb injectors and an enthalpy tuned ecu.
GT3582R SR20 Powered S13
mastaflash05 is offline   Reply With Quote
Old 03-28-2005, 09:11 PM   #2
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
thats alot of fuel ur gonna be running planning on a 500hp+ car? im doing the same thing u are.. im probably going to have to purchase the AEI-13101... thats more then enough, the other side of the fuel rail is your return line i believe... why would u need 2 inlets unless u plan on running alcohol or some other shit... hope that helps
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 03-29-2005, 04:11 PM   #3
mastaflash05
yeah i do plan on haveing around 500 or so hp eventually. id rather buy more than i need now than to but less and have to buy something bigger down the road.
Old 03-31-2005, 07:44 AM   #4
mastaflash05
nobody else?
Old 03-31-2005, 07:51 AM   #5
the head
the head's Avatar
you want a single inlet single outlet unit with a 30-70 psi pressure range and no return
Old 03-31-2005, 08:56 AM   #6
mastaflash05
yeah i figured that i needed single in and out, but i wasnt sure what was meant by the return. i gues im going to go with the compact series. thanks for the help.
Old 03-31-2005, 01:51 PM   #7
infinitexsound
youll be alright just dont get 2 inlets unless u plan on running alcohol injected also...... make sure u have the right fittings... to go with ur fuel rail
Old 03-31-2005, 02:24 PM   #8
mastaflash05
no i dont really plan to run alhohol injection or anything like that. im going to just use rubber hose, and get barbed fittings for now. i dont want to plop down the money for all the AN fittings and stainles line at this time. ill upgrade to that later on.
Old 03-31-2005, 03:07 PM   #9
the head
the head's Avatar
i would go with AN if you need to use the black aeroquip line or the earls econo line and jegs or some other inexpensive fittings you are best to go AN throughout especially since i doubt you could find fittings that go from -10 to barb anyways
Old 03-31-2005, 06:27 PM   #10
infinitexsound
Old 03-31-2005, 10:00 PM   #11
mastaflash05
as far as fittings and lines i stil need to se what i need to get.
