Old 04-04-2005, 10:37 PM   #1
smithers584
smithers584 is an unknown quantity at this point
just got back from the dyno
hey guys i just got back from the dyno and i put out 232hp and 233tq
i was just wondering if this sounds accurate or if i can pull more power.
my boost controller was set at one bar and here are my engine mods
walbaro pump
stock t25 on s13 blacktop
hks intake
greddy fmic
safc II
greddy downpipe
CIP test pipe
apexi gt exhaust
q45 90mm mas airflow sensor
act street strip clutch
apexi AVCR
thats all i can remember for that, let me know what you guys think.
smithers584 is offline   Reply With Quote
Old 04-04-2005, 10:42 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
1bar sounds awfully high to be pushing out of the stock t25. Numbers sound perfectly good to me though.Time for cams/intake manifold
wootwoot is offline   Reply With Quote
Old 04-04-2005, 11:45 PM   #3
one_tyme
one_tyme is an unknown quantity at this point
1bar is fine with the stock t25, ive been doing it for over a year with lots of racing and drifting, and up until my recent turbo upgrade, the turbo and engine was fine.
im assuming your numbers are whp>? if so, thats pretty damn good if you ask me. i think you are very near your max potential. i would leave it as is. if i was you, i wouldnt add cams or an intake manifold to get more HP, especially with your set-up now. at 15psi you are near max on turbo and injector duty may be high. the cost for the cams or manifold will not be the HP gained by it, if any. ive seen people put cams and IM to a stock turbo set-up and actually get slower and lose HP.
sorry for straying off-topic. good job on your numbers!!!!
one_tyme is offline   Reply With Quote
Old 04-05-2005, 12:32 AM   #4
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Thats all you can get out of your t25 without running higher timing which would turn your motor into a time bomb.
Cams and intake manifold will make your car feel like poo, and will loose power.
Time for injectors, then turbo, then maf.
You could be close to 300 whp with s15 turbo, injectors, and a maf.
anything past that i would reccomend a bigger intercooler and head gasket at the least.
good job with the dyno. which ecu were you running?
blu808 is offline   Reply With Quote
Old 04-05-2005, 12:50 AM   #5
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
isn't greddy intercoolers are known to handle up to 400? I won't go bigger for power 300-400hp cause I have seen the greddy FMIC and it's pretty big. Yea next would be injectors, bigger turbo and I would dyno tune after new injectors.
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 04-05-2005, 01:59 AM   #6
Flybert
At 1 BAR, I would assume you'd be making around 240-250whp from what I've seen. At that point like blu808 said, you are running nearly max injector duty so maybe it's good you aren't making more power but I'm curious why you are a little low. Is your timing set correctly. Is that SAFC tuned to work with that MAFS. Did you get a wideband readout?
