Old 04-13-2005, 04:01 PM   #1
JDMark
JDMark is an unknown quantity at this point
Send a message via AIM to JDMark
lifter tick?
so after running my engine really hard at high rpms, it ticks. it goes away a little bit afterwards. i was told it was lifter tick, and my friend who had the same problem (and same engine) said when he changed his oil from 10w40 to 10w30 it made it go away. im running 10w30 tho he said it was the valvetrain gettin starved of oil for a little bit, causing lifters to tick. what could i replace that would eliminate this problem? oil pump? eh?
its an SOHC engine with 170k, just redid my timing chain (it did it before that as well). what do you all think? thanks
-mark
JDMark is offline   Reply With Quote
Old 04-13-2005, 04:30 PM   #2
s13gonwild
s13gonwild is an unknown quantity at this point
I get this problems sometimes too, its a lifter getting stuck..i usually goes away on my car too. I think changing the oil pump may help..maybe its going out and you dont get as much oil to the head...worth a shot...i just deal with it im just waiting til this motor goes to swap so im riding it out LOL still runs strong and wont go 260k miles on it...KAs are solid.
s13gonwild is offline   Reply With Quote
Old 04-13-2005, 07:10 PM   #3
my240iguanas
my240iguanas is an unknown quantity at this point
Send a message via AIM to my240iguanas
its the oil , i had the problem you can go with 10-40 or you can use the oil additives or treatments . The make the bad noise go away
my240iguanas is offline   Reply With Quote
Old 04-13-2005, 08:03 PM   #4
JDMark
someone recomended seafoaming the engine, im gonna do that and let you guys know if it helped. do it this weekend prob.
Old 04-14-2005, 12:35 AM   #5
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Hydraulic lifters are very susceptable to failure due to lack of lubrication. Make sure you are using the correct oil specified.
Your lifter tick could be a couple of things:
1. Dirt or wear in the lifter check valve.
2. Low oil pressure or excessive wear between the lifter body and its plunger.
3. Or you could have air in your oil from the crackcase being overfilled.
4. Maybe sticking due to varnish from imporper maitenace.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
