Old 04-24-2005, 11:37 AM   #1
Jumpman-Z
Jumpman-Z's Avatar
Jumpman-Z is an unknown quantity at this point
Need to disable power steering... What size belt?
As I previously posted in another thread, my power steering hose is screwed, and I don't really have time to replace it. It seems the best solution is to just disable it for now by taking off the belt. I noticed in the FSR that it's also connected to the water pump, I'll need a shorter belt. For those who have done it, what size belt do I need? Also, anything else that I should know? It's a 93. Thanks in advance.
03 350Z Track --- 90 300ZX TT
Garage Antics Youtube
Jumpman-Z is offline   Reply With Quote
Old 04-24-2005, 12:17 PM   #2
wa22jimmy
wa22jimmy's Avatar
wa22jimmy is an unknown quantity at this point
Send a message via AIM to wa22jimmy
you could just get a tape measure and see how long the belt needs to be. cut the old belt and wrap it around the crank pulley and water pump. get your local part store idiot to compare the size to other belts they have.
NASTY BEHIND THE WHEEL BUT MY MIND AINT STEER'D RIGHT
wa22jimmy is offline   Reply With Quote
Old 04-24-2005, 12:21 PM   #3
Phlip
Yes, I look like that
Phlip's Avatar
When you measure it, take that measurement, use the letters that start the model number of your belt and take into the parts store, the belt will have a number in the p/n, that is the length (like 31-32 or some shit like that) all you do is subsititute your measured length in there for what you removed, that is how we did when I shitcanned A/C
Weirdo
And I write too!
Old 04-24-2005, 01:22 PM   #4
wa22jimmy
wa22jimmy's Avatar
i was going to say that on a DOHC motor you can just remove the belt but i saw you have a SOHC
Old 04-24-2005, 02:03 PM   #5
SilviaSativa
SilviaSativa's Avatar
SilviaSativa is an unknown quantity at this point
Ganked from my first search result.
Originally Posted by 1998cc
Napa V-Ribbed Belt (Its a gates belt)
25 030267
13/32" x 27 3/38" or 11mm x 695mm
That belt is a tight fit so here is the procedure for getting it on.
loosen all the bolts on the crank pulley and leave two on (the top ones), loosen the water pump bolts but leave two on (the bottom ones), then slide the belt on and press the belt on hard while turning the crank. Slowly after maybe 3-5 turns of the crank it will be completely on. then put on and tighten all the bolts. Do a simple test run, see if everything is ok.
This is the belt I, and many other people are using, though there is little-to-none belt deflection.
Next time I replace the belt, I think I could do it without unbolting anything, just turning the crank and letting it work itself on.
About 4500K put on it and no problems yet, just a little stiffy..
SilviaSativa is offline   Reply With Quote
Old 04-24-2005, 05:04 PM   #6
Jumpman-Z
Jumpman-Z's Avatar
Thanks SilviaSativa, just the information I was looking for. Didn't see it in search. I wouldn't have been able to take my belf of to do measurements, since the S13's my only ride right now. Thanks for the help, everyone.
Old 04-24-2005, 06:44 PM   #7
neverdone
neverdone is an unknown quantity at this point
Will this be able to hold up for an extended period of time? Also is the AC pump belt connected to anything else besides the crank?
neverdone is offline   Reply With Quote
Old 04-24-2005, 08:45 PM   #8
someguy_240
someguy_240's Avatar
someguy_240 is an unknown quantity at this point
Send a message via AIM to someguy_240
if the 93 has the same belts as a 98 then its a 695mm belt 3 ribbed v-belt wid a underdrive pulley
i bought the belt at napa auto parts cant really remember the manufature think it started wid a g not sure, hope that helps, dan
"...But my tires were wet!"
someguy_240 is offline   Reply With Quote
Old 05-02-2005, 08:07 PM   #9
kahlistrophic
kahlistrophic's Avatar
kahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of lightkahlistrophic is a glorious beacon of light
so what r u gonna do with the ps?....its heavy isnt it? did you guys leave ther pump and hoses in?
kahlistrophic is offline   Reply With Quote
Old 05-02-2005, 08:24 PM   #10
Phlip
Phlip's Avatar
^^^ If he was just leaving the pump there, you jackass, what would be the point of removing it?
Weirdo
And I write too!
Old 05-02-2005, 08:51 PM   #11
Ritz S14
Ritz S14's Avatar
Learn how to read guys.
Ritz S14 is offline   Reply With Quote
Old 05-02-2005, 09:08 PM   #12
Phlip
Phlip's Avatar
NO, nonononononononononono, I was responding to this:
Weirdo
And I write too!
Old 05-02-2005, 10:45 PM   #13
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
by the way, a 270k4 with one rib cut off fits perfectly that extra "3" gives it just the right amount of deflection
black s13 is offline   Reply With Quote
Old 05-03-2005, 12:52 AM   #14
sw20>>s14
sw20>>s14's Avatar
wont having no belt deflection mess up the water pump's bearing? the belt tension is supposed to have up to 10mm of deflection or it might be too tight...
sw20>>s14 is offline   Reply With Quote
Old 05-03-2005, 04:31 PM   #15
kahlistrophic
peoples minds do change...hence need for the question... and...yes...reading does help...
"There is no fail when there is no win!"
-Break Win Garage
Old 06-05-2005, 12:48 PM   #16
chris-r
chris-r is an unknown quantity at this point
Whats the best way to turn the crank? i cant move mines is there some kind of procedure to have it so it can move?
chris-r is offline   Reply With Quote
