Old 05-03-2005, 10:05 AM   #1
dreamer
dreamer is an unknown quantity at this point
DIY side skirt installation tips?
whats up i have some fiberglass ebay side skirts and im trying to figure out how to make them sit flush against the car. i tried that double sided tape stuff, but it doesnt stick to the fiberglass!
dreamer is offline   Reply With Quote
Old 05-03-2005, 10:11 AM   #2
llteddy4playll
llteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-known
3m will stick did you use a heat gun and clean it real good? All of the kits will not sit flush. You would have to put screws in it then fill it in then paint it. Or you can just mold it on. Or get a body shop to modify it.
llteddy4playll is offline   Reply With Quote
Old 05-03-2005, 10:14 AM   #3
dreamer
i used 3m ... but i did not use a heat gun.... so you're supposed to melt it a bit?
Old 05-03-2005, 10:19 AM   #4
llteddy4playll
When you heat it up itll stick like super glue. So make sure you line it up before you stick it to the car.
Old 05-03-2005, 10:21 AM   #5
dreamer
innnteresting... sounds good. except 1 thing. i dont have a heat gun. could i use my gf's hair dryer or something? or is that not hot enough?
Old 05-03-2005, 10:25 AM   #6
llteddy4playll
itll be good
Old 05-03-2005, 10:29 AM   #7
dreamer
im goin to try it right now! haha thanks for the help
Old 05-04-2005, 03:29 AM   #8
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
if you can find a heat gun, heat up the fiberglass till its slightly pliable then shape it flush to your car.. thats what body shops do to make kits flush... im just going to do 2 tiny screws on each side though.
s13silady is offline   Reply With Quote
Old 03-06-2012, 01:56 AM   #9
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
DIY link anyone. Been searching for 2 days here and NRR.
TIA
CH
Sent from my DROID RAZR
heychris is offline   Reply With Quote
