Totally glazed over my rotors! Now what?
OK I've posted this problem about my ebrake never working right, it won't lock the rears, it takes 10+ seconds to fully lock, etc, etc.
I took it over a friends house to have the ebrake cables swapped out, he takes off the wheel, and says "Ummm I don't think your ebrake is the problem, your rear rotors are totally glazed over". I'm running cross-drilled and slotted Brembo rotors front and rear, Project Mu Type NS front pads and Mu D1 Spec rear pads. Now I'm not sure what to do at this point. Do I need all new rotors and pads? Or just rotors? Why the hell would my rear rotors be completely glazed over if I'm using street brake pads? I thought that only happened with crappy pads. ![]() And whats the best way to avoid this happening again? I have no idea how the hell my rotors got like this to begin with.
![]() KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! Last edited by JaeTea; 05-16-2005 at 09:14 PM.. |
![]() Join Date: Apr 2002
Get them turned/cut? I'd at least try that before you go spending the money on new rotors. Also, did your friend check the pads to make sure they weren't glazed over as well?
were the rotors zinc coated? did you let let the pads break? I've heard stories of people having problems with the coated rotors but don't know how true they are.
89 S13 hatch/////98 Subaru 2.5RS Last edited by TheTimanator; 05-16-2005 at 08:54 PM.. |
![]() Join Date: Jul 2002
Make sure that your e-brake is disengaging completely. You could glaze the rotors if you just drove around for a little while with the e-brake engaged.
Allen Delta Region SCCA SM 1990 240SX SR20DET |
have them turned with a non-directional lathe, can help prevent it.
If you want to try it, a die grinder and an aggressive scotch pad (I think the correct name) can be used to deglaze and give them a non-directional finish. |
They were zinc coated and you can't turn/cut slotted-cross drilled rotors.
Not sure if the pads were glazed but I'm buying new ones.
![]() KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! |
if you get chemicals on your rotors like grease and the friction makes it all blinged. your rotors and ur pads become slippy so friction is limited so your brakes arnt griping.
are you leaking anything in that area? |
#10 | |
Somehow the rotors got glazed within a few days after installing my pads and rotors because my ebrake never worked since then ![]()
