Old 06-01-2005, 07:38 AM   #1
xagna
xagna has a little shameless behavior in the past
New megan coilovers after 50 miles and some problems.
Have droven with a pair of new megan coilovers in the rear for about 50 miles with the dampers set at damper to soft. (I havent installed front pair yet.)
At the beginning, the ride was very harsh. The spring oscillated too much. But handle felt very light. The way car shifted its momentum to any direction that I steered was very fast and dynamic. The car felt light.
After the 50 miles, I changed damper setting to most hard out of curiocity. Guess what...
The light handle feel is gone and car doesn't exhibit the momentum transfer as dynamic as it used to. The car feels sluggish and heavy.
What is happening?
xagna is offline   Reply With Quote
Old 06-01-2005, 09:02 AM   #2
Redsunz916
Redsunz916's Avatar
Redsunz916 is an unknown quantity at this point
they are from ebay. everything ebay BRAnd sux
Redsunz916 is offline   Reply With Quote
Old 06-01-2005, 09:10 AM   #3
sw20>>s14
sw20>>s14's Avatar
i cant understand what your saying. but...why dont you install all four corners, and get an alignment. then see what happens...
what are you talking about? ebay has a lot of good parts now...best bang for your buck factor...plus, you'd be suprised how good the quality of those megans are...some might even say...a'pexi quality (brass instuments: DUN, DUN, DUUUUUUUUUN!...)
sw20>>s14 is offline   Reply With Quote
Old 06-01-2005, 09:14 AM   #4
OptionZero
OptionZero's Avatar
alot of what the poster described seems pretty subjective and personal. It could merely be inexperience overall, rather than a problem with hardware
Have you ever had coilovers before?
Old 06-01-2005, 09:37 AM   #5
Redsunz916
Redsunz916's Avatar
hey i got my gab coilovers from ebay, im not saying EBay is bad, Ive ordered like clear corners and ish like that in the past and they suck. Stuff like that. but some things on ebay are gold and worth buying.
Maybe just play with ur settings on ur coilovers, too bad u dont know anyone with some megan coilovers to give u some feed back on them. I saw a write up on the megans in FA.com go search it i know for a fact theres a thread that explains the goods and the bads.
Old 06-01-2005, 09:40 AM   #6
Ritz S14
Ritz S14's Avatar
Come back when you have the front coilovers installed. Then tell us what you think.
After two drift events, and roughly 2,000 miles of driving, my MR coilovers seem to be holding up pretty well. No complaints, other than having a 32-way adjustable shock is just 16-18 clicks, too many.
Ritz S14 is offline   Reply With Quote
Old 06-01-2005, 09:46 AM   #7
xagna
Got the MRs from underground.
It could be my inexperience but my senses are not deceiving me. Handling and maneuvering became worse as I changed from soft to hard and when I changed back to soft from hard, the handling and maneuvering feels same.
Old 06-01-2005, 10:02 AM   #8
sw20>>s14
sw20>>s14's Avatar
well, its all weight transfer and rebound/comp. just think about how drastically it would alter the handling if you had stiff ass rear and sloppy ass stock front (i dont have MRs, but ive read that when one person put it on the stiffest, he could feel the lines at the cross walk while driving over them)? then changing over to sloppy ass stock front and a "slightly stiffer than stock" rear? its going to mess with the whole car...just do all four, dial in what you want and everybodys happy
Old 06-01-2005, 02:21 PM   #9
90RS13
90RS13 is an unknown quantity at this point
I've had mine I guess for about 2k miles now and they still feel great. I really think a car would feel retarded with that drastic of a difference between front and back spring rates, and dampening. Also, the front will effect turn in alot more than the back. As far as feeling sluggish, mine car feels anything but that. Going to Frankfurt a couple weekends ago, I had to pay super close attention driving, cause cruisin at only 110mph on the autobahn, the car reacts quickly to anything. If I barely move the wheel it darts across the road and when I hit cracks and bumps the car tries to "skip" around. On a side note though the KA24E held up great. 110mph for an hour, and it didn't blink. At 175k miles on her, that's pretty cool.
P.S. That Megan exhaust kills you at 100+. You have to yell at the person in the pasenger seat to talk. BTW, anyone have a MR silencer they don't want?
90RS13 is offline   Reply With Quote
Old 06-01-2005, 03:06 PM   #10
OptionZero
OptionZero's Avatar
didn't read that part about only having the rears
why on earth would you only install half your coilovers and then complain about handling? jeez...
Old 06-01-2005, 03:33 PM   #11
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
You = bitchslapped.
Would you ride a bike with only one wheel? No
Would you skate without a board? No
Don't do things halfassed. It gives you halfass quality, and makes you spend even more time doing it when you have to go back and fix what you just did.
get the fronts in already, it'll change your driving characteristics likenight and day.
SochBAT is offline   Reply With Quote
Old 06-01-2005, 03:56 PM   #12
xagna
Because lack of time I didn't get to install the rear. Sun went down. Work light was not bright enough.
I do know stock front and aftermarket in the back would result in something truly ugly. But what I don't understand is that the combination of stock and MR in the rear was pretty good in terms of handling and cornering in the very beginning and it got ugly when I changed the damper setting to hard setting for the first time.
Old 06-01-2005, 04:20 PM   #13
mrmephistopheles
mrmephistopheles's Avatar
WTF. Which is it? Front or rear?
Originally Posted by PHLIP
Old 06-01-2005, 04:25 PM   #14
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
Jsut put the damn fornt ones on first then see how it is
dood it takes like 20 minutes
rim_bender is offline   Reply With Quote
Old 06-01-2005, 04:40 PM   #15
Ritz S14
Ritz S14's Avatar
It's front. He made another thread questioning if you had to dremmel the front C/Os for bolt fitment. Answer. No.
Old 06-01-2005, 05:03 PM   #16
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Man, the bottom line is you need to install both to truly get a feel for the car.
Think about.........on the soft setting your rear will have characteristics closer to the front stock shocks. But when you stiffen the rear up like crazy its going to really throw your car out of wack. All of a sudden you have your rear which won't give an inch and front which freely gives a yard. (exaggeration)
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 06-01-2005, 07:05 PM   #17
vinhisbored
vinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enough
Send a message via AIM to vinhisbored
yes, when both front and rear are installed, come back. there is no wonder why your ride was rough. your front/rear differs so much. + the fact that many people said, you maybe just havnt felt coilovers before.
vinhisbored is offline   Reply With Quote
Old 06-01-2005, 07:35 PM   #18
xagna
Sorry to confuse you.
It is the front that I haven't been able to install because of time.
It may be too late to ask at this point but are there things you have to do on your coilovers after they are installed besides cleaning up your driveway and test driving your thing around a block? Say like not to put the damper into hard setting upto certain miles after the install or to keep drive slow until the damper gets settled?
Old 06-01-2005, 07:37 PM   #19
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
seriously... and it should only take you about 5 mins per corner anyway *rolls eyes*
wutangben is offline   Reply With Quote
Old 06-01-2005, 07:41 PM   #20
Var
Var's Avatar
Send a message via AIM to Var
install your coils, set to middle setting, and try not to crash.
Hi
Old 06-01-2005, 10:09 PM   #21
xagna
Thanks for the advices.
After changing the damper setting, how soon does an effect of a new damper setting take place?
Old 06-01-2005, 11:44 PM   #22
Ritz S14
Ritz S14's Avatar
Instantly
Old 06-02-2005, 02:38 AM   #23
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Redsunz916, you from running free???
Yeah, seriously, get the whold set in. That'd be like changing just the oil and not the filter, you're missing out of its full potential.
Pacman is offline   Reply With Quote
Old 06-02-2005, 11:13 AM   #24
Redsunz916
Redsunz916's Avatar
Yup yup i know who u r
Old 06-02-2005, 02:30 PM   #25
S14DB
AFC #1
S14DB's Avatar
There is a reason they come as a set of FOUR. You should install them at the same time. How you're driving now is unsafe. You're lucky you haven't spun out and killed someone.
Let me try to be a little more direct with what the other users are trying to say: STFU till you get the front coilovers installed.
Old 06-06-2005, 07:23 AM   #26
umsports
umsports's Avatar
umsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura about
Guys, he is probably a honda convert....Give him some space.....
Just picking man...But yeah, you need to install all 4...This is the first time I've ever heard a complaint after only installing two of them....hum....
Actually this is the first time I've ever heard of only installing two....
Regards,
Chris
2010 R35 GTR 600whp @21 PSI (E85)
1998 RB26DETT 240SX 810whp@28lbs
umsports is offline   Reply With Quote
Old 06-06-2005, 09:29 AM   #27
raen419
raen419 is an unknown quantity at this point
Send a message via AIM to raen419
wow, this is really sad.
why do people go out and buy shit w/o knowing what it does, how it works (eventhough MR's come w/ a diagram...and it's perfectly readable)?
get all four on. drive the car. enjoy it.
then get an alignment.
raen419 is offline   Reply With Quote
Old 06-06-2005, 05:16 PM   #28
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
no such thing as "suspension settling down" it's a stpuid myth a few ricers made up.
if the springs are built correctly. they should be fine the first time.
Get all 4 installed then start bitching.
I hope you understand what damping means. the car will feel different from different settings.
it sounds like your first set of coilovers. Your center of gravity will be lower and your handling will be better. Maybe you can't handle your car?? The problem isn't the coilovers, it's your intelligence.
driftingisgay.com
nrg is offline   Reply With Quote
Old 06-07-2005, 04:02 AM   #29
kandyflip445
kandyflip445's Avatar
Even the guy that sold them to him kinda took a stab at it.
Did you get them on yet? Any better?
My 240 vBgarage
Old 06-07-2005, 07:49 AM   #30
tiggs
tiggs is an unknown quantity at this point
here you go, a link to his newest thread showing that he has all 4 installed now
http://www.zilvia.net/f/showthread.php?t=81897
tiggs is offline   Reply With Quote
