Old 05-31-2005, 12:05 PM   #1
Romeyo07
Romeyo07 is an unknown quantity at this point
Send a message via AIM to Romeyo07 Send a message via MSN to Romeyo07 Send a message via Yahoo to Romeyo07
e-brake cable issue
So my e-brake never worked since I've owned the car. I haven't had the time to see why until recently. So I took off my center console thing and all of the cables are still intact. My assumption is that somewhere between the inside of my car and the brake, something is wrong, loose, or broken.
Is there a common thing to happen to our e-brakes for this to happen? Maybe a weak point that I should check first? Any help is appreciated. I don't have a lot of time on my hands to inspect too into depth, but I know I'll have to do it.
Romeyo07 is offline   Reply With Quote
Old 05-31-2005, 12:12 PM   #2
aznpoopy
aznpoopy's Avatar
another easy inspection:
jack up the rear, take off the wheels and make sure the ebrake line is connected to the rear calipers, and they are aligned with the hash marks.
Old 05-31-2005, 02:45 PM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
just make shure the ebrake cable is still there... under the car and everything is still connected.... tighten the nut on the handbrake... what kind of car?
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-01-2005, 12:03 PM   #4
Romeyo07
92 240SX
I bought another e-brake cable a long time ago thinking that it was missing, but why would the previous owner remove it. They had it for about 7-8 years before I picked it up. I'm hoping something just popped out and I can pop it back in or something.
Old 06-01-2005, 02:20 PM   #5
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
loosen the ebrake line to give it some slack, jack up the car, remove rear wheels, and check out the ebrake line in the rear. They should be sittin on a fork tightly.
SochBAT is offline   Reply With Quote
Old 06-01-2005, 06:00 PM   #6
infinitexsound
bada bing bada bang bada boom...^
Old 06-02-2005, 09:11 AM   #7
exitspeed
aWingThing.com
exitspeed's Avatar
What if the passenger side one is not sitting in the fork tightly? My e-brake has also went and after inspecting it I can see all the cables and they don't appear to be snapped anywere. I did tighten the bolt under the e-brake handle itslef and it did retighten the throw of the handle, but still no e-brake response.
Old 06-03-2005, 03:06 AM   #8
SochBAT
hmmm... check the other side. make sure the ebrake is loosen when you are correcting this, or else you'll have one hell of a time. That was what i ws feeling when i frist got my car. the tire only locked one side (drivers) cuz it was the only one connected. make sure both sides are connected, then look around the driveshaft area. Don't bash my drawing, you peehole!
Make sure those cylinderical nubs are in the sockets. its kinda hard doing it whn you can't get good light down there, but that should help. Hit me up on AIM if you need a quick response.
Old 06-03-2005, 03:09 AM   #9
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
reasons for lines to brake would be not enough slack for lines and an over zealous driftAR!!!!
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 06-04-2005, 02:01 AM   #10
SochBAT
^ Ignore him...
