Old 03-22-2002, 09:57 AM   #1
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
ok, here is my situation.
-check engine light on
-running  rich
-rough idle
-LOUD BANGING noise from #1 cyclinder(loud) as if there is chain slap!!
help me please
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 03-22-2002, 10:09 AM   #2
yenpit
yenpit is an unknown quantity at this point
with the engine still running (i assume it still runs), don't rev it up, pull the #1 spark plug wire out (loosen it b4 you start the engine, leave it all the way down in the hole) using a rubber handled pliers or something (so you don't zap urself with the ignition spark <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/butbut.gif" border="0" valign="absmiddle" alt=':but:'> &nbsp. IF the "banging" sound gets quieter, could be bad news......could be a wasted conn rod bearing or wrist pin bushing (on piston). i jumped to this diagnosis cuz ur car is turbo'd, right?
if it's more of a "slapping" noise, i suppose it could be the timing chain prob that these cars have... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'>. good luck!
'98 240SX 5spd[br]http://www.speedwisemotorsports.com
yenpit is offline   Reply With Quote
Old 03-22-2002, 11:04 AM   #3
boosteds14
boosteds14's Avatar
that could be the cause for this but remeber that i had the motor rebuilt and i just got it running last week. it has less than 100 miles on it. maybe it could be &nbsp;the timing.
240SXONE
Old 03-22-2002, 12:08 PM   #4
boosteds14
boosteds14's Avatar
i got another question, its a dumb one but it just popped up in my head.
suppose if i put the distributor in backwards(meaning that the when the #1 cyclinder is suppose to fire, the #4 &nbsp;cyclinder is actually firing)
wouldnt the car not even run?/
pplus, could it be the knock sensor, i had a hard time trying to put the connector on, ,maybe thats why i am getting check engine light? and with bad timing it could run like shit.
i dunno, tonight i am going to check everything, so please give me suggestions
240SXONE
Old 03-22-2002, 08:10 PM   #5
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Have you checked the code your computer's throwing? &nbsp;That may help a bit to see what's causing the CEL to come on, which may determine what's wrong w/ your engine.
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 03-22-2002, 08:36 PM   #6
daywalker
daywalker is an unknown quantity at this point
Take your oil filter off and saw it in half and look for metal shavings also drain the oil and put a magnet in the oil to also search for metal shavings.If that comes out negative take the plug out and see if the elactrode is gone. Now if everything comes out fine drop your oil pan and check the crank cuz you might of spun a bearing on it. Did you use clevite bearings?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Norbert
91 Eclipse GSX
96 240 SE KA-T
http://www.PhatKA-T.com
http://www.Sound-Performance.com
daywalker is offline   Reply With Quote
Old 03-22-2002, 09:24 PM   #7
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
knock snesors dont trip engine lights which is very weird. trust me i work at nissan and all the techs even say so. i dont know why and the techs said something but i forgot what it was. i know they couldnt explain it correctly though
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
