Old 06-13-2005, 02:57 PM   #1
Carlwill
Carlwill's Avatar
Carlwill is an unknown quantity at this point
Piston seals?
I am pulling the head of my motor and was wondering since the motor is out, should I replace the piston seal rings? I know they sit in the block and not the head but since my motor will be out and I am replacing stuff, is it worth my wild to swap them out on a Red Top? I don't if they need to be replaced but I figure better safe than sorry - any opinions?
How hard are they to get to once the head is removed and the top of the pistons are exposed? Or must I remove the crank
Linux System Administrator
rm -Vfr /etc/*nix "Love is a fist"
Carlwill is offline   Reply With Quote
Old 06-13-2005, 03:36 PM   #2
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
changing piston rings while block is in the car is not something u want to try. yes it is possible, but on our cars it involves dropping half of the front suspenison so oil pan can come out just to access rod bolts.
1 not fun.
2 no where near worth the trouble, if u intend to do it, pull motor, itll be cleaner(hence better job) and way easier that way
ultraDorksGarage is offline   Reply With Quote
Old 06-13-2005, 03:52 PM   #3
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
you minus well but then you minus well change the main bearings, rod bearings and studs. I mean no use in taking one thing out and leaving old parts in. Shit your half way there. I wouldnt just do the piston rings because the bearings and all the other stuff mentioned would suffer because of age/wear.
kick rocks.
Buffalo Daughter is offline   Reply With Quote
Old 06-13-2005, 07:20 PM   #4
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
You shouldn't replace the piston rings without a honing job.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 06-13-2005, 07:59 PM   #5
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
not worth the trouble, IMO, unless the block is really old.
if its not broken, why fix it?
Chernobyl is offline   Reply With Quote
