Old 06-15-2005, 08:38 AM   #1
linkwpc
linkwpc's Avatar
linkwpc is an unknown quantity at this point
More and more backfiring?
I have SR20 S15 for a while now and when I first got the car with the SR it never backfire or very very little. Now 7 months later it’s backfiring all the time. Manly between all shift points it will do a light backfire when it warms up. Is there a way to fix it to do less backfiring or is there something wrong with my SR?
97 240SX! 10 Camaro SS (SOLD - 95 W/S15 SR20 6M tran)
linkwpc is offline   Reply With Quote
Old 06-15-2005, 09:00 AM   #2
uno
uno is an unknown quantity at this point
Send a message via ICQ to uno
probably timing or incomplete fuel burn
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels.
uno is offline   Reply With Quote
Old 06-15-2005, 09:30 AM   #3
the head
the head's Avatar
if you run an atmo BOV recircing it will help some
possibly new plugs? Car may be running rich and therefore fouling plugs
Old 06-15-2005, 09:46 AM   #4
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
yeah just recirculate your blow off valve and it should stop most of the backfiring. It is a common thing for turbo charged vehicles to back fire a bit.
g2ic02 is offline   Reply With Quote
Old 06-15-2005, 10:22 AM   #5
linkwpc
linkwpc's Avatar
hhhmm I do have my BOV recirculating right now.....
Old 06-15-2005, 11:04 AM   #6
uno
check plugs, plug gap and timing
Old 06-15-2005, 11:58 AM   #7
bdeisle
bdeisle is an unknown quantity at this point
i just had the same problem, and i had to replace my fpr, just gave up on me and was sticking.
93 h/b. ka24de-t3(14), enthapy controlled .20bore, weistco 8.5.1cr, gReddy FMIC, E/L mani,t3 turbo to a 3in D/P to a HKS(88mm)HiPower and for cool sound effects the oldskool HKS Superblow, and you ask what about fuel? let me tell you 580cc, yes i said 580cc's, act clutch/flywheel. Buy my Coolio trading cardz!
bdeisle is offline   Reply With Quote
Old 06-15-2005, 01:44 PM   #8
SDS14Driver
SDS14Driver is an unknown quantity at this point
i agree with the timing or possible unburned fuel bein blown up cause of your EGT. If you really wanna get to the root of your problem, find out why back firing occurs in the first place.
Taking it a step further, why back firing occurs in turbo charged vehicles and try to apply what you learned to your situation.
good luck.
SDS14Driver is offline   Reply With Quote
Old 06-16-2005, 06:56 AM   #9
linkwpc
linkwpc's Avatar
So should I change all my plugs? If so what kind of plugs should I get? Well I have thinking that I'm running too rich. I go about 18 miles to the gallon. So thats no good. So should I go get my ECU tuned to fix the going too rich problem? By the way bdeisle, what fpr mean?
Old 06-16-2005, 09:55 AM   #10
g2ic02
fuel pressure regulator=fpr
Old 06-16-2005, 10:55 AM   #11
bdeisle
depending on how bad the backfire.. i wouldnt drive or hit boost at all without knowing the issue, its not workth det. and blowing up your motor.. and in sr check coil packs and the ignitor
