Old 06-17-2005, 02:52 PM   #1
Hypertek99
Hypertek99 is a well-known jackass
Yes another overheating problem!!!
Ok the car over heats to the bar before the H then drops back down to normal then after a few more minutes of driving it goes back up then starts to climb for H. I had a crack in the radiator so i changed it out yesterday for a new one. But it's still overheating. After i shut off the car now i can hear in the radiator like it's sucking??? and bubbles blow into the overflow tank. It's a 89 Ka24e can anyone tell me what's wrong?
Hypertek99 is offline   Reply With Quote
Old 06-17-2005, 05:34 PM   #2
zfinger
zfinger's Avatar
zfinger is an unknown quantity at this point
Send a message via AIM to zfinger
try jacking up the front as high as you can, and take off the radiator cap. sounds like you have air in the system.
zfinger is offline   Reply With Quote
Old 06-17-2005, 05:55 PM   #3
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
Or maybe open the breather valve located next to the intake manifold.....
stillmatic is offline   Reply With Quote
Old 06-17-2005, 05:57 PM   #4
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
hypertec is right.one thing to add is after you jack up front of hte car remove bleeder screw(10mil) and start prouring coolant in to the radiator untill you see it run out of the bleeder screw.
then you're done
what i really recomend to everyone who does their own service is this
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
with this you can eliminate pretty much all the air out of your system. same procedure jack it up close open bleeder bolt then let car run for 20mins (or until thermostat opens once or twice)or so with heat ON .
Al_S14 is offline   Reply With Quote
