Old 06-19-2005, 02:23 AM   #1
trevor
trevor is an unknown quantity at this point
hicas rack and pinion
i have to get a new rack and pinion so i was thinking of up grading while i was at it. i was searching and found out the hicas rack has a quicker turning ratio than the stock 2 wheel turning rack and pinion but does it turn as far rack i have now (non hicas)? thanks. and i did search.
trevor
trevor is offline   Reply With Quote
Old 06-19-2005, 02:57 AM   #2
Flybert
It turns just as far as the non-hicas rack.
Old 06-19-2005, 01:34 PM   #3
trevor
thanks thats all i needed to know
Old 06-19-2005, 02:29 PM   #4
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
If you want more steering angle, get tie-rod spacers.
Victor
Mike Wazowski is offline   Reply With Quote
Old 06-19-2005, 05:40 PM   #5
trevor
thats what i was planing to do when i replace my rack and pinion becaus mine is leaking. no point in getting an alignment twice. thanks
trevor
Old 06-19-2005, 06:23 PM   #6
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
The advantage of the Hicas rack, is the fact that with a quicker turning ratio, it means your input i.e. when you turn the steering wheel, will result in a faster steering wheel to wheel response. Which translates to less slop in your steering in general and much more responsive turning ability. Giving more of a direct input response with no lag effect. i.e. you turn your wheel and then your wheels turn on non hicas vs you turn your wheel and your wheels turn on a Hicas rack.
I personally prefer the Hicas rack over the stock rack for all types of driving due to this. Its the way all of the racks should have been setup for our cars IMHO.
New Video
Buy my mounts!
