Old 06-24-2005, 09:10 AM   #1
Carlwill
Carlwill's Avatar
Carlwill is an unknown quantity at this point
SR20 Shim Confusion
Ok, am I not understanding this correctly or am I just confused.
I sliped 3 rocker arms total on both the intake and the exhaust side per a mis-shift. So now that means I have 3 sets of rocker arm shims losse in my motor. So now I have 3 guides and 3 shims for the 3 rocker arms that need to be reseated on top of the valve springs. Due to me being retarded, I lost one of the guides for the rocker arm and when i call to get a replacement per the Nissan part # 13218-53J00, they ask me what size?
I tell this dude I don't know the size so that is why I have the part #. He then says each rocker arm has a individual specific size shim and guide so I will need to measure it. I told him if I could measure it, I would not need to order one.
Is this correct or am I missing something here. I have 3 sets of shims and I don't know if they each go to a specific rocker arm or what
Linux System Administrator
rm -Vfr /etc/*nix "Love is a fist"
Carlwill is offline   Reply With Quote
Old 06-24-2005, 12:02 PM   #2
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
yeah you cant just throw them back in there
each rocker arm goes with one of those shims and one of those guides. They are not all the same. So you got to figure out what combination of shim, guide, and rocker arms all go together.
rim_bender is offline   Reply With Quote
Old 06-24-2005, 07:59 PM   #3
usctom
usctom is an unknown quantity at this point
The only thing that has a size is the shim. I think Id be more worried about where those shims and guides are. When this happened to me I found two in the oil pan. One of them was on top of the baffle and one in the pan.
usctom is offline   Reply With Quote
Old 06-25-2005, 08:28 AM   #4
Carlwill
Carlwill's Avatar
So you're saying that the shims are only sized and the guides are all the same? The guid just seems to hug the rim of the rocker arm and I know all rocker arms are the same size. I would think the round shims are different sizes and the guides are the same.
Old 06-25-2005, 10:10 AM   #5
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
as far as i know the guides should be the same and the shims should only be slightly different
sncs14 is offline   Reply With Quote
Old 06-25-2005, 10:37 AM   #6
usctom
yes the guides are all the same size. I think they are .121 inches. If i you look in the FSM you can find all the possible sizes and also how to go about choosing the size you need.
Tom
Old 06-25-2005, 02:02 PM   #7
Carlwill
Carlwill's Avatar
Is there a FSM online? .PDF?
Old 10-06-2006, 07:09 PM   #8
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
Yes, all guides are the same size. They are only available in one size. The shim is what varies. Ive listed all the sizes here:
http://www.mynismo.com/products/?id=5834
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
