Old 07-12-2005, 05:33 AM   #1
joobojesse
joobojesse is an unknown quantity at this point
Rear Camber...
I know a lot of people want a few degrees of negative camber for their cars for drifting, but i drive across the country twice a year in my s13, and right now i just want 0 camber (or near there) so i dont wear down my michelin pilots too fast.
I have heard that you can just slot the rear upper control arm holes and save a good 300 bucks that could otherwise go into other needed mods. Has anyone done this?? Does it hold up to drifting well??
I have the sportline/blues setup, btw.
http://www.240sx.org/links/installs/camber/camber.html
joobojesse is offline   Reply With Quote
Old 07-12-2005, 08:05 AM   #2
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
" Camber is degree in which your tires contact the road, and if its not 0 or there about, you will get bad tire wear. "
That sentence, is not correct. Your tire and suspension do things when you take a corner or when you acccelerate. I would say -.75 - -1.25 would probably give you optimal wear. Would probably handle better also.
KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST
lilredstiffy is offline   Reply With Quote
Old 07-12-2005, 08:08 AM   #3
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
^^^ yes. -.75 rear -1 front is somewhat very modest on tire wear.
my personal favourite, -1.25 front -1 rear for a very modest camber
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 07-12-2005, 12:50 PM   #4
joobojesse
ok, assuming i want whatever camber you guys are talking about.... have you heard of anyone doing the grinding thing??
Old 07-12-2005, 01:18 PM   #5
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
yes i have and it's stupid. your alignment will get whacky after any amount of hard driving.
s0ldats is offline   Reply With Quote
Old 07-12-2005, 02:15 PM   #6
Var
Var's Avatar
Send a message via AIM to Var
The title of your thread reads "Rear Camber"
As far as i understand you can slot it all you want but the rear upper control arm which is bolted to the top of the hub controls camber in the rear, therefore making your shock assembly bend in at the top for no reason while the RUCA keeps the camber the same.
Hi
Old 07-12-2005, 10:28 PM   #7
joobojesse
ok, thanks... looks like rucas are the next step! But do i heeed just the loop thingie, or do i need the bar thingie aswell??
Old 07-12-2005, 10:55 PM   #8
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Just the "loop thingy". The "bar thingy" is a traction rod.
www.splparts.com has awesome thingies. I got my thingies from them.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 07-13-2005, 02:11 AM   #9
Stock-S13
Stock-S13 can only hope to improve
^^^ Worst SPL plug to date!
Oh well atleast your getting his name out there.
Also thier are varations on what settings accomedate each other; suspension mods, tire/wheel size weight of the car etc.. I know nothing about drifting nor will i pretend to but a rather close contact of mine is familiar with the aspects of it.
And in my opinion I would NEVER slot any of my suspension pieces.
Also, let me see if I understand this correctly- you drift yet you fear premature tire wear, or wear at all? Hmmm... Change sport perhaps.
I think if you kept up with an allignment you would be fine.
Stock-S13 is offline   Reply With Quote
Old 07-13-2005, 01:46 PM   #10
LigouriRd
LigouriRd's Avatar
LigouriRd will become famous soon enoughLigouriRd will become famous soon enoughLigouriRd will become famous soon enough
Um, camber is not what wears out tires. TOE DOES. The reason a lot of people wear out tires when they drop their car is that as the suspension compresses the rear toe increases along with camber. Its the tires pointing inward and the tops leaning inward that wears out the inner tread. If the toe was practically zero there would be no wear. Camber helps you corner by keeping the tire perpendicular to the ground as the car's body rolls. You want a slight amount of negative camber...unless all you do is drive in a straight line.
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk
LigouriRd is offline   Reply With Quote
Old 07-13-2005, 07:59 PM   #11
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
toe will fuck up tires big time... I used wheels/tires from my altima, they weren't new, but they were gone pretty damn fast...
that's why I am putting on Toe rods with RUCA, nice ajustability....
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 07-13-2005, 08:11 PM   #12
joobojesse
No, dont drift when driving in a straight line across the country. There is no point in wasting expensive tires for no reason... no need to be a dickfor
