Old 08-02-2005, 06:30 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
difference between s14 kouki jdm and usdm turn signals
ok so i went from usdm front bumper to jdm bumper
on the usdm bumper, the clear turn signal is in the front, and the amber lamp is on the side that lights up as like a running light i guess you could say
when you switch to jdm bumper, its just the turn signal, and it wraps around the whole way.
id like to have the turn signals work as running lights, and then blink when i want to turn in whichever direction
is this possible?
thanks
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 08-02-2005, 07:18 PM   #2
projectRDM
projectRDM's Avatar
IIRC, they come with two 2pin sockets. Fine a 3pin socket that will fit, or use the 2pins and wire one for parking, one for turn.
FORMERLY R240NA
Old 08-02-2005, 09:06 PM   #3
devonkyle77
where can u get those?
Old 08-02-2005, 10:19 PM   #4
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
If you feel like going for something different, you could always just drill a hole to fit a LED in the sides, add a correct resistor and then tap the power off your exsisting sider markers. A decent sized amber LED in both sides might look good for a marker and haven's seen it done so far.....origionality +1...... not quite as quick and easy as the bulb replacement, but it's Just a thought
Tenchuu is offline   Reply With Quote
