Old 08-18-2005, 06:32 AM   #1
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
BOV mounting/recirculating
I'm forming some ideas about my BOV positioning in the engine bay. Nothing quite seems to be pointed in the right direction. The flange for the BOV either points it towards the firewall, or at about 4:30, and neither is especially helpful in getting the discharge recirculated to the stock rubber SR intake tube. I have no idea how to re-clock the flange other than cutting it off and re-welding it and that's really not an option.
Would you guys mind posting some pics of where your BOV is mounted, and how you've recirculated it?
TIA
Rittmeister is offline   Reply With Quote
Old 08-18-2005, 12:39 PM   #2
Flybert
Go get it cut and rewelded. Pay someone to do it. You don't need to do it yourself. It's that or you can just go buy hoses that have bends and link them together with brass fittings to meet up with your recirc fitting. It'll make your engine bay more cluttered though.
Old 08-18-2005, 01:01 PM   #3
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
You can barely see it but it's under the cold pipe (almost impossible to tune but looks nice =) I used Home depot clear tube and brass plumping pipe bends. They'll have everything you need.
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
Old 08-18-2005, 06:37 PM   #4
iMAGE976's Avatar
iMAGE976 is making a name for him/her selfiMAGE976 is making a name for him/her self
Send a message via AIM to iMAGE976
u should check the Picture thread ...theres quite a few pics of engine bays in there with BOVs that are visible.Hope that helps.....
iMAGE976 is offline   Reply With Quote
Old 08-19-2005, 08:58 AM   #5
adoboboy
adoboboy's Avatar
adoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really nice
Send a message via AIM to adoboboy
i've seen bov's on the hot side and cold side of the ic...Does it matter? Is there any performance difference? it would be easier to recirc. the bov if its on the hot side...but the pressure surge will have to go thru the IC then to the bov, fairly close to the turbine.
adoboboy is offline   Reply With Quote
Old 08-19-2005, 10:01 AM   #6
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
its better to have on cold side close to the throttle body. The reason manufatures of FMIC kits put their BOV flange on the hot side is so that you could easily recirculate. I have my BOV on the cold side and im recirculating also... hose running across the engine bay (=
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 08-20-2005, 08:59 PM   #7
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
I use Enjuku's hot pipe and their welded bung is actually threaded, so mostly any flange can be used as long as it matches threads. Essentially, you can turn the flange any way you want and face the BOV any way you want, just make sure to use something to make sure it seals well, some kind of taflon tape. If you need a pic of mine, go to my thread at:
http://www.zilvia.net/f/showthread.php?t=87320
Pepperoni is offline   Reply With Quote
Old 08-20-2005, 11:21 PM   #8
turbozxi
turbozxi is an unknown quantity at this point
Bollocks why is it better to have it on the coldside? It is better on the hotside from what I have seen, there is just not as much room as the coldside.
turbozxi is offline   Reply With Quote
