Old 08-24-2005, 11:41 AM   #1
dpreuss
dpreuss is an unknown quantity at this point
Power steering rack fitting
One more quick question. Instead of buying different hard lines for the ps pressure line for my sr swap, i want to run a braided line fromt the pump to the rack. I already know the fitting in need at the pump, but i just need to know what fitting i need to go into the rack. So if anybody knows what fitting i would need, please let me know. thanks. -Derek
dpreuss is offline   Reply With Quote
Old 08-24-2005, 07:02 PM   #2
projectRDM
projectRDM's Avatar
Remove it and match it up, You'll need the flare type with an o-ring anyway, best to make certain it's right.
FORMERLY R240NA
Old 08-24-2005, 10:06 PM   #3
docrice
docrice's Avatar
docrice is an unknown quantity at this point
Send a message via AIM to docrice
braided lines for power steering? isn't that a bit overkill/waste of money?
docrice is offline   Reply With Quote
Old 08-25-2005, 01:08 AM   #4
dpreuss
its cheaper than buying new hard lines
Old 08-25-2005, 01:22 AM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
we ran custom lines with a transmission cooler for my RB swap because the stock steering lines could not be used.
New Video
Buy my mounts!
Old 08-25-2005, 07:21 AM   #6
Johny5
Johny5's Avatar
ahahaha, good luck going to the track and turning multiple times with regular braided steel lines. here's some literature for you guys.
http://chevyhiperformance.com/howto/4399/
"Power Steering Hose Is Different
Although you've probably seen it dozens of times, regular stainless braided AN hose should not be used for power-steering hose applications. Pressure spikes in the power-steering system can exceed the burst strength of regular AN hose. That is why companies like Aeroquip and Earl's have developed specific power-steering hose, complete with its own unique steel fittings, for use in these systems. Power-steering hose is usually made of an elastomer tube, polyester inner braid with wire-braid reinforcement, and a polyester-braid cover. Its maximum operating pressure is rated at 2,250 psi. While ideally suited for steering and hydraulic systems, this type of hose can be used in other applications including fuel, oil, and compressed air. Most Winston Cup pit crews use this type of hose with their "over-the-wall" air tools because of its flexibility and extreme pressure-spike capabilities in case it gets run over."
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 08-25-2005, 07:33 AM   #7
docrice
docrice's Avatar
Excellent info Johny5!
Old 08-25-2005, 08:53 AM   #8
dpreuss
thanks for the info, but i do have the power steering hose made by areoquip, i just need to know what fittings to get
Old 08-25-2005, 10:46 AM   #9
FRpilot
FRpilot's Avatar
this is an interesting thread. can you post pictures of it when you get it on the car depreuss?
FRpilot is offline   Reply With Quote
Old 08-25-2005, 12:02 PM   #10
dpreuss
yeah, i will post pics of my entire swap when i get done, does anyone know who i could contact to find out the size of fitting i need? I already tried phase 2 and heavythrottle, neither of them knew. Thanks - Derek
Old 08-25-2005, 01:09 PM   #11
Johny5
Johny5's Avatar
hey i'll have some help for you soon. i'm doing fitting sizes on my s14 steering rack as i've been considering doing stainless braided ps as well. using the proper 2500psi braided hose and steel fittings of course. but i'll have fitting sizes soon.
Old 08-25-2005, 01:11 PM   #12
Johny5
Johny5's Avatar
p.s. please do share what fitting is used on the pump, i'll find rack fittings because i have a spare rack but i need to know what a ka pump uses. we're referring to the top one thats high psi and normally uses banjo bolt right? are you gonna do a 90 degree there instead of banjo?
Old 08-25-2005, 07:45 PM   #13
dpreuss
I actually bought that part of the line from advance auto parts. Its a line from the banjo fitting that runs into a block with 2 holes, one for the sensor, and one for the hard line to the rack to screw into. You can look at it here
http://www.partsamerica.com/ProductD...ype=18&ptset=A
However, i do know the banjo fitting you need. You will need a 15mm banjo fitting to go into the pump. I hope I have helped, and i do thank you in advance for your help in finding the fitting size for me. Thanks again -Derek
Old 08-28-2005, 12:05 PM   #14
dpreuss
Let me know when you find that fitting size for the rack johnny 5
Old 08-28-2005, 01:56 PM   #15
Johny5
Johny5's Avatar
should be soon man
just gotta get the motor out and the rack off the car.
