Old 08-29-2005, 03:51 PM   #1
Revolver Ocelot
Revolver Ocelot's Avatar
Revolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of light
Send a message via AIM to Revolver Ocelot
Clutch slipping, not disengaging?
Ok today when i was driving in second i gave it a little gas and instead of going it reved, like the clutch was in. It continued to do this in all of the gears. If i baby it it is fine, but if i give it anymore then quarter throttle it will rev and then finally catch. Has this happened to anyone else or does anyone have an explanation for this? Its a brand new clutch by the way on a 95 Ka.
Originally Posted by R240NA
240 owners = cheap, lazy fucks. If it involves more than two bolts, they didn't do it.
Revolver Ocelot is offline   Reply With Quote
Old 08-29-2005, 04:50 PM   #2
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Hmmm might want to check the clutch adjustment nut above the clutch pedal, if it's adjusted too much the clutch will slip when up to operating temps.
Once I adjusted mine a little too much to remove some of the "slack" in the pedal... I did this at night while the car was cool. The next day I drove somewhere and for the first 10+ minutes of the drive the clutch was fine but after things got warmed up it started slipping and revving with any throttle. I backed the adj nut off a little and the problem went away (and the slack came back... hehe)
GL
MELLO*SOS is offline   Reply With Quote
Old 08-29-2005, 04:53 PM   #3
Revolver Ocelot
Ill try that. Yea its fine when its cold but when it warms up it happens. And i did adjust the pedal recently.
Old 08-29-2005, 08:20 PM   #4
SimpleSexy180
dont forget to check for leaks in the lines and slave cylinder. I used to have a somewhat similiar problem but mine was because the clutch fork was not being pulled back all the way.
SimpleSexy180 is offline   Reply With Quote
Old 08-29-2005, 08:42 PM   #5
Revolver Ocelot
Alright thanks, ill check that too. The problem seems to be solved, for now. But why would adjusting the pedal cause the clutch to slip?
Old 08-30-2005, 12:13 AM   #6
snp_ethan
snp_ethan is an unknown quantity at this point
Send a message via AIM to snp_ethan
if all fails(and keeps slipping) then be careful your disk is worn out , but if your pressure plate goes bad, you are Fed, thats a 10 hour process of separating the tranny to the shaft and all that.. and its gonna be a biatch..
snp_ethan is offline   Reply With Quote
Old 08-30-2005, 07:45 PM   #7
Revolver Ocelot
Alright slipping problem is fixed and the pedal still has good pressure. But it tends to grind in second and third if i either shift to fast or at high rpms. I basically have to baby it now and make sure the clutch pedal goes down to the floor. Anybody else have any insight on this annoying problem.
Old 08-30-2005, 10:14 PM   #8
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Well kinda the same thing happened to me, loosen the two bolts on the tranny that hold the clutch slave cylinder in place and slide the cylinder closer to the fork then tighten it back. It will only give you about a milimeter of adjustement but trust me that little adjustment makes a huge difference. being closer basically makes the slave move the fork that much further.
But from how it sounds you could have some bad gears or syncros on your tranny, so you might wanna get that checked also.
smily_vigor is offline   Reply With Quote
Old 08-31-2005, 06:13 AM   #9
aznpoopy
aznpoopy's Avatar
bleed... i would do a flush actually
Old 08-31-2005, 10:13 AM   #10
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
s13
Yup I'd suggest the same.. Also might want to consider removing the clutch damper while you're under the car: http://garage.projectraine.com/conte...chdamper01.htm
You probably did what I did, and that's adjust the majority of "slack" (dead feeling between pedal rest and actual engagement) out of the pedal -- while the car is cold. Then when you drive and things get up to operating temperature, your adjustment is basically keeping the clutch pedal depressed slightly which causes the clutch to slip and the engine to rev while in gear.... Not a good feeling!!
GL
Old 08-31-2005, 01:26 PM   #11
Revolver Ocelot
Thanks for the help guys.
