Old 09-04-2005, 04:24 PM   #1
aznpoopy
aznpoopy's Avatar
ka24de... started twice, won't hold idle
so, i finally got a lull in school and went out to the car
we started screwing around with the timing trying to get it started
it started twice but wouldnt hold idle, with the dist rotated all one way. off by a tooth i think.
we retimed it, but by then we had cranked it so many times the damn battery box was dead and we had to call it a day.
q#1 - idle speed adjustment screw. i don't care if it idles at 2000 rpms, as long as it idles so i can do a preliminary timing. which way to open it up? i'm guessing counterclockwise, but its always good to ask.
q#2 - aligning the distributor. 3 marks on the dist shaft; yellow, mark one and a big mark at the top. one mark at the base of the shaft (the part that doesnt spin); you line up the big mark at the top with the mark on the shaft, according to the FSM. now my question is... do you account for that when you insert the distributor; so that it lines up to that position when it turns during insertion; or do you just line it up and then stick it in like that and let the rotor spin where it wants to (i.e. nissan was smart enough to plan for it)?
Old 09-04-2005, 08:50 PM   #2
240SeXy!
240SeXy!'s Avatar
240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known
Simple thing before you continue, Wont hold idle? MAF?
240SeXy! is offline   Reply With Quote
Old 09-05-2005, 01:15 PM   #3
aznpoopy
aznpoopy's Avatar
timing was off car runs, aznpoopy is happy
BAZOW YAY FUCK YEAH XD XD XD
Old 10-17-2005, 12:52 AM   #4
SR20Inside
SR20Inside is an unknown quantity at this point
Send a message via AIM to SR20Inside Send a message via MSN to SR20Inside
How did you fix your timing?
Current Vehicles: HP10 DE + GT28RS AND MUCH MORE :P / S13 STOCK
SR20Inside is offline   Reply With Quote
Old 10-17-2005, 09:59 AM   #5
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
have you checked the idle air control valve? its at the back of the intake manifold. it might need to be cleaned, i recomend replacing it so you dont have to worry abotu it again, vaccum issue? bad erg? maf?
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 10-17-2005, 04:11 PM   #6
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
did you even bother reading this post?
Tenchuu is offline   Reply With Quote
