Old 09-06-2005, 02:48 PM   #1
Nismo240SX
Nismo240SX's Avatar
Nismo240SX is on a distinguished road
Send a message via AIM to Nismo240SX
SR swap into 90' automatic... confusion?
okay, i'm swaping in a red-top into my automatic sohc. i've finished the labor part in the 5spd. swap, just having some confusion on which plug is the ignition kep capture , and any other plugs that need to be disconnected underneath the steering column.(pictures would be great) also, i'm confused on which plug needs to be wired together in the engine bay. i've found two plugs that have two thick wires. i think one is black and one is grey. and now to my power steering questions. the sohc routes the power steering on the wrong side. i've re-located my reservior to the drivers side, i have my lines to the pump from a dohc, and i'm just darn right confused about what to do with the hardlines that run to the wrong side and where they should end up. i'm thinking of just getting rubber lines and running them back to the drivers side. will there be any ill effects from that, or anyone have any pictures of what i should do? any help will be greatly appreciated. any flaming will be ignored, specially about not having a fsm. thanks so much.
1990 Nissan 240sx:s13 blacktop, s13.5 front
Nismo240SX is offline   Reply With Quote
Old 09-06-2005, 02:50 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Moving to Tech Talk where this belongs.
Old 09-06-2005, 04:40 PM   #3
Nismo240SX
Nismo240SX's Avatar
oh yeah, one more thing... can i use a o2 sensor from a 91-94 SER? or where can i get an o2 sensor bung for a SSA J-pipe? thanks
Old 09-06-2005, 06:18 PM   #4
Nismo240SX
Nismo240SX's Avatar
please i need help asap!
Old 09-09-2005, 11:26 AM   #5
Nismo240SX
Nismo240SX's Avatar
okay, i figured out the powersteering and its fixed. now i just need to know which sensor/sensors need to be removed from underneath the dash.
Old 09-13-2005, 12:27 PM   #6
quad_ova
quad_ova is an unknown quantity at this point
Send a message via AIM to quad_ova
maybe this will help
Hey when I did my 5 speed swap I didn't unplug a thing under the steering column, I got pissed cause I took all that apart for nothing. I have a 1990 and in the engine people said to splice those 2 plugs or something, which didnt work. On mine, there were 2 plugs around the fuse box. One of the plugs I found was directly under the fuse box. Just stick your hand under there and feel for a plug. the three plugs are the same style connector. if what I wrote is confusing, pm me and I will rewrite it.
sorry, heres a cleaner version I think the three plugs were something like plug 1 on fuse box: white wire and black/yellow. plug 2 on fuse box: white wire and black white, the 3rd plug had black white and black yellow (I think this one was on the tranny side of the wires)
Just match up the colors. Just so you know the white wire is the 12v constant, the black/yellow is a starter wire, and the black/white is a starter wire as well. So it would be a good idea to disconnect the battery, leave the key out of the ignition, car out of gear, and make sure there are no idiots near your steering column and keys.
Back after 10 years...
quad_ova is offline   Reply With Quote
