Old 09-22-2005, 01:36 AM   #1
sucker4stalefish
sucker4stalefish is an unknown quantity at this point
tension support bar?
is that what you call the piece that the bushing end of the tension rod bolts into? mines bent to where you cant even get the rod out...
sucker4stalefish is offline   Reply With Quote
Old 09-22-2005, 01:52 AM   #2
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
i call it a tension rod bracket. You could alwys upgrade to a Nismo powerbrace, or MickeyMouse powerbracing DIY style. It cleans up the slop steering.
SochBAT is offline   Reply With Quote
Old 09-22-2005, 07:41 AM   #3
projectRDM
projectRDM's Avatar
Tension rod bracket is the correct name.
FORMERLY R240NA
Old 09-22-2005, 09:55 AM   #4
kandyflip445
kandyflip445's Avatar
If you have a s13 get a Nismo Power Brace. It replaces both tension rod brackets and is reinforced in the brackets and between the brackets. Huge difference felt on an s13.
My 240 vBgarage
Old 09-22-2005, 01:29 PM   #5
A Spec Products
A Spec Products's Avatar
heat and a BFH never fail
pound back into shape
A SPEC PRODUCTS CORP
Old 09-22-2005, 03:14 PM   #6
m0rex
m0rex's Avatar
m0rex is on a distinguished road
Oh it does fail. Just replace it with some $5 dollar oem ones. I just got the nismo power brace instead of oem since i had the money for it at the time.
m0rex is offline   Reply With Quote
Old 09-22-2005, 04:07 PM   #7
OptionZero
OptionZero's Avatar
wouldn't stiffening up the front result in more understeer, or does it not function like a front sway or strut bar?
Old 09-22-2005, 04:58 PM   #8
SochBAT
I don't think it'd function as those. I'd say it works as an enhancer of sorts.
IIRC, While driving, you've only got about 80% responsiveness with the wheel. Being as the TRB are seperate, it'd allow unwanted flexing and movement of the tension rods. By solidifying the braces with rigid panels and a bar, slop and flex are eliminated, increasing steering response to 90%+, depending.
Or maybe im just talkin out of my ass. One of those.
Old 09-23-2005, 09:28 AM   #9
kandyflip445
It doesn't create understeer. Chassis braces don't function like sway bars. They just strengthen the chassis so it doesn't lead to alignment changes due to it flexing. What sochbat said is true, other than the numbers he used. Cause he has nothing to back it up, it's more of an assumption.
My 240 vBgarage
Old 09-23-2005, 02:01 PM   #10
SochBAT
I was kinda regurgitating what i've heard from numerous people about the %tile of steering response. So my answer was a little bit of both. My anus speaks the TRUTH!
Old 09-23-2005, 04:53 PM   #11
sucker4stalefish
does anybody have a pair of these brackets they want to get rid of?
Old 09-23-2005, 06:40 PM   #12
kandyflip445
You're in luck! I have my stock ones in my garage. PM me your shipping info and I'll get you my paypal thingy. I'll ship them and then you can send me the money for shipping.
My 240 vBgarage
