Old 09-24-2005, 08:28 PM   #1
justeno_heat
justeno_heat is an unknown quantity at this point
Send a message via AIM to justeno_heat
I got the head bolts out of my SR but can't get the head off
I just need some help on ways to take off my head. It just seems stuck on the block, and I can't figure out how to pull it off. So if anyone has done this could you give me some ideas.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
2 10" JL Audio W3's with Kenwood head unit
Erebuni carbon fiber hood
Koyo aluminum radiatior
240 down for the Summer FROWNING
If NISMO stands for Nissan Motorsports, wouldn't Honda Motorsports be HOMO?
justeno_heat is offline   Reply With Quote
Old 09-24-2005, 09:00 PM   #2
240mph
240mph's Avatar
240mph is making a name for him/her self240mph is making a name for him/her self
Send a message via AIM to 240mph Send a message via MSN to 240mph
You say everything is completely off right?
If it seems to be stuck, take a rubber mallet
and slightly tape the edges around the head.
That should take it off.
240mph is offline   Reply With Quote
Old 09-24-2005, 09:03 PM   #3
kandyflip445
kandyflip445's Avatar
Yep do what he said. Don't use a screwdriver or anything cause you could damage the gasket mating surfaces and then would require some work to make it nice again.
My 240 vBgarage
Old 09-24-2005, 09:05 PM   #4
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
did you get the 3 10mm bolts also?
there are 2 up front about 2 inches below the top of the head on the inside of the timing chain area...and one small 10mm in the rear
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 09-24-2005, 09:08 PM   #5
240mph
240mph's Avatar
Yeah I was thinking he forgot to take out some bolts.
Usually the head should come off easily with a slight tug.
Check the bolts RedSuns mentioned.
Old 09-24-2005, 10:27 PM   #6
sub_version
sub_version is an unknown quantity at this point
Don't forget to remove the timing chain tensioner...
sub_version is offline   Reply With Quote
Old 09-24-2005, 11:06 PM   #7
Irukandji
usually the head will be stuck there from being pressed on for how many years its been sitting inside a silvia clip. just go with the rubber mallet, if that doesnt work... then double check to make sure all the fasteners are taken off
Old 09-25-2005, 12:32 PM   #8
justeno_heat
Yeah I took off the 2 bolts in the front but I didn't notice the one in the back yet. I'll go out and take that out then. The timing chain tensoner though, how do I take that out?
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
Old 09-25-2005, 05:55 PM   #9
justeno_heat
Hey RedSuns, where is the bolt in the rear of the engine? I can't seem to find it anywhere.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
Old 09-25-2005, 06:41 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Theres 2 bolts inside front of the head that attaches to the oilpump cover, one on the outside by cam angle area *look around the water neck*, another on the back side corner of the engine by the crankcase breather.
CLICK HERE!!!
Old 09-25-2005, 06:51 PM   #11
justeno_heat
I know this might sound dumb but where is the crankcase breather at?
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
Old 09-25-2005, 09:32 PM   #12
fliprayzin240sx
Back right *driver side* corner of the engine
CLICK HERE!!!
Old 09-26-2005, 09:34 PM   #13
powerls
powerls is an unknown quantity at this point
All I can say is "BFH." That should work just fine hehe
powerls is offline   Reply With Quote
Old 09-27-2005, 06:20 AM   #14
RedSuns
RedSuns's Avatar
rear corner of the head on exhaust side
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
