Old 09-25-2005, 09:06 PM   #1
Omega47
Omega47 is an unknown quantity at this point
s13 LSD conversion?
I was searching on ebay for an LSD rear for my s13,and i saw this...
LSD Insert
Have searched a few times on this forum and others,cant seem to find anyone who has used this,what do you think? Will it work? Worth it?
Omega47 is offline   Reply With Quote
Old 09-25-2005, 09:15 PM   #2
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
NO, its not. Phantom = Not there.
No-There Grip. Makes sense. For that amount, you can find a decent used LSD, or VLSD.
Hell, since i can tell you're going to skimp on things, weld the diff.
Our Limited Slip Differential will
provide you with:
Maximized Tire Wear
hahahahaha!
SochBAT is offline   Reply With Quote
Old 09-25-2005, 09:42 PM   #3
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
any disadvantages to welding the diff???
If welding diff can achieve a 2way LSD effect, why are there even 2 way LSDs?
Sonic Motor is offline   Reply With Quote
Old 09-25-2005, 09:44 PM   #4
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
I suggest you click on the search button....
welded diff -> 2 way lsd at all times, so no limiste slip, but locked at all time.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 09-25-2005, 10:29 PM   #5
SochBAT
Welded the diff makes it 100% locked, ie, a solid 2way.
Advantages : earlier initiation, faster cornering, knowing when it'll slip
Disadvan. : understeer, chirping, and being JDM Tyte.
Old 09-25-2005, 10:37 PM   #6
S14DB
AFC #1
S14DB's Avatar
Phantom Slip, We eat spider gears for breakfast!
Old 09-25-2005, 11:57 PM   #7
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
2 ways can disengages removing the chirping, tire wear that welded diffs come with. But 2 way LSDs and run deep into your pockets!!
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 09-26-2005, 07:21 AM   #8
broken_s13
broken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enough
It says when cornering and braking it act likes a clutch type, and under acceleration it gives power to both wheels. Sounds like a 1.5 way to me. But cheeper. From the looks of the way it was designed, itll probably wear the spider grears down. Give it a try. i
broken_s13 is offline   Reply With Quote
Old 09-26-2005, 10:54 AM   #9
OptionZero
OptionZero's Avatar
No. Don't.
Old 09-26-2005, 11:19 AM   #10
Dousan_PG
Dousan_PG's Avatar
this shit is so old
the phantom grip is a pos
it WILL break under drifting or hard driving circumstances, ist been tested by regular folks, and it failed
quit being cheap and either weld your diff or shell out for a real LSD (hlsd, vlsd, lsd clutch)
Aaron
Pink GodziRa
Old 09-26-2005, 11:47 AM   #11
OptionZero
OptionZero's Avatar
actually, isn't it just being stupid? That's more expensive than a junkyard VLSD, and maybe more expensive than a Welded diff
Old 09-26-2005, 11:56 AM   #12
chlatboy
buy it and see how it works. You can learn a good lesson from it. You get what you pay for and dont be cheap with stuff u put on your car. Only cheap mod that have seemed to work fine would be a welded diff.
If you dont know
SEARCH!!!
Old 09-26-2005, 11:59 AM   #13
thekman
thekman is an unknown quantity at this point
yeah that is a pos
thekman is offline   Reply With Quote
Old 09-26-2005, 12:10 PM   #14
P_s14
P_s14's Avatar
P_s14 is an unknown quantity at this point
Send a message via AIM to P_s14
I bought a VLSD off a j30 for less than that
P_s14 is offline   Reply With Quote
Old 09-26-2005, 01:36 PM   #15
projectRDM
projectRDM's Avatar
And more work too.
FORMERLY R240NA
Old 09-26-2005, 02:48 PM   #16
Omega47
You guys dont seem to understand i asked an opinion of it,no where did i say i was going to get it...and i wont weld the diff that is half assed. I said i was looking for an LSD and saw this.
Old 09-26-2005, 02:53 PM   #17
ranisron
what's wrong with welded diff?
do a quick search on welded diff, and see if you like it.
I rode in an S13 with welded diff, didn't feel anything awkward, other than... in reverse. hhaaa.
U13 and S13
Old 09-26-2005, 02:59 PM   #18
chlatboy
Originally Posted by Omega47
Thanks for the opinions and suggestions... and i wont weld the diff that is half assed. So instead of going halfass by welded up a diff, which is proven on tracks that they kick butt, im going to invest my life's saving for a high end, high quality Phantom Grip.
Sound better?
If you dont know
SEARCH!!!
Old 09-26-2005, 08:50 PM   #19
Toka Motorsports
Toka Motorsports's Avatar
Toka Motorsports is a well-known jackass
there is no point to weld a diff... me and some freinds tried it on a Rustang(mustang) the gears will weld but the welds crack apart even from the lighest driving. we opened the diff and welded everything that touched and even welded some steel strips onto the gears... but it still cracked like crusty bread.. later we put like half an inch of extra steel into the diff.. it looked like it was fool proof but the power from the four cylinder rustang ripped the welds aprat again... and we ended up buying a junk yard diff to replace the ruined one... it may work on some diffs but running the car hard... it will crack...
Toka Motorsports is offline   Reply With Quote
Old 09-26-2005, 08:54 PM   #20
S14DB
AFC #1
S14DB's Avatar
Dang, Someone sucks at welding.
Old 09-26-2005, 10:39 PM   #21
SochBAT
HALLELUJAH!!!! If that is even spelled right...
Old 09-27-2005, 04:31 AM   #22
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
+2 Noob welders probobly should stay away.. get a Weld Locd Ver3 from Luke!!
ERRRRR wrong again! http://www.shockdrifting.com/weldlocd.html
educate yourself
Just because you guys suck and welding doesn't mean a GOOD welded diff sucks.
Then don't get welded! Get Phantom grip for your diff. Then when it breaks and owns you I'll laugh because my welded diff will still be working perfectly fine.
Welded diff half assed?
That car doesn't look very half assed, but is still rocking a welded diff.
What exactly makes a welded diff half assed to you? You obviously have no clue what your talking about because you didn't even bother to do a search on phantom grip. So how would you know if welded is "half assed"
EDIT: I refuse to believe that you serached. Found this on the very first page of the search.
http://www.zilvia.net/f/showthread.p...t=phantom+grip
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 09-27-2005, 10:23 AM   #23
chlatboy
Like what was said thousands of times before, one of the only bang for your buck mod would be a welded diff. But forget about welded. Phantom for the win!!
Get 3 or 4 of them so that you wont have to pay more shipping every time one breaks.
If you dont know
SEARCH!!!
