Old 09-29-2005, 12:48 PM   #1
scotland200sx
scotland200sx is an unknown quantity at this point
boost gauge question
i have just fitted a boost gauge,
when the car is idling is the reading suppose to be -6?
i took it for a run and when the boost kicks in i get a + reading.
i take it that 0 on the gauge is the moment the boost comes on?
scotland200sx is offline   Reply With Quote
Old 09-29-2005, 12:57 PM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Im around -18 at idle.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 09-29-2005, 01:43 PM   #3
Andrew Bohan
-20 is ideal. most people are around -18 or -19 at idle.
you have a vacuum leak.
Old 09-29-2005, 02:17 PM   #4
ALTRNTV
When I had my SR back then, I was always at -18 at idle. Yes, 0 is when boost starts, or actually 1.
ALTRNTV is offline   Reply With Quote
Old 09-29-2005, 02:27 PM   #5
scotland200sx
how do i find a vaccum leak?
what symtoms can a vaccum leak cause?
its a digital gauge so i might have a bad connection
Old 09-29-2005, 02:30 PM   #6
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
you should probrably check your vaccum lines and intercooler piping and make sure there isnt any are leaking. Or get a can of Carb cleaner and just start spraying areas where you think may be leaking, your idle will fluctuate if you spray into the leak.
Eternal_240Sx is offline   Reply With Quote
Old 09-29-2005, 03:31 PM   #7
scotland200sx
cheers!!
the digital boost gauge screen layout is like -0.0
how would it show double digit numbers?
ill check for vaccum leaks
Old 09-29-2005, 05:17 PM   #8
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
you got to be fuckin kidding me..... when it idles it should be at 0.
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 09-29-2005, 05:18 PM   #9
Var
Var's Avatar
Send a message via AIM to Var
boost guage should read 0, but a vacuum/boost guage should read negative 10 or around there. cause it's in psi not inches of mercury
Hi
Old 09-29-2005, 05:55 PM   #10
420sx
420sx's Avatar
hmm....maybe my boost gauge's teflon line got a cut/hole somewhere. cheap crap....
hydropgrahics!
ls1......
Old 09-29-2005, 06:00 PM   #11
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Var, -10???
maybe u got a leak too! LOL!
I was always told that -20 is idea, but -15-20 is prolly the realm of reality.... I hover around -17 at operating temp.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 09-30-2005, 12:26 AM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
I'm KA-T and I'm about 18,19 PSIat idle.. don't know if it's diff for sr
Old 09-30-2005, 04:04 AM   #13
scotland200sx
just went to my local performance car garage (www.crdracing.co.uk)
they said that -.5 at idle is about right(0 in an ideal world). if its at -20 then there is somthing wrong with the compression in the engine or the connection to the boost gauge is in the wrong place. i still get a reading of 7 when at full boost witch is correct for a stock sr20det.
Old 09-30-2005, 04:31 AM   #14
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
vaccum reading depends on what has been done to the engine. with upgrade cams and head job, the vaccum presure reading on my friend's car was at 10 IN HG. My stock sr20 reads 18 IN HG.
scotland, i think you're confused from BAR and IN hg reading. your -.5 bar sounds about right.
driftingisgay.com
nrg is offline   Reply With Quote
Old 09-30-2005, 08:05 AM   #15
the head
the head's Avatar
what unit of measure is your gauge in?
the numbers you are recieving here are for boost PSI and vor vacuum IN/HG (inches of mercury) sounds like your system is running on somthing else (BAR possibly)
Old 09-30-2005, 10:18 AM   #16
Yoshi
Yoshi's Avatar
sorry doode
like the head & nrg said, we measure mostly in PSI (positive/boost), and Hg (vacuum). You being in scotland, yet another awesome country pillaged by the brits :P, i'm pretty sure your shop is giving you measurements in BAR.
I think .5 bar = -14.77Hg
So that's about the right ballpark.
Give us a pic of your boost gauge if u want to be sure
Old 09-30-2005, 02:19 PM   #17
Var
Var's Avatar
Originally Posted by Yoshi
Var, -10???
meh..what does it matter now. i dont even own a 240. LOL.?? i dunno man. i remember my Profec E-01 being around -10, but maybe it was 18. The display is hard to see during the day.
Hi
Old 10-01-2005, 03:16 PM   #18
scotland200sx
Its in BAR
sorry for the confusion.
