Old 10-15-2005, 06:17 AM   #1
pepsicola
pepsicola is an unknown quantity at this point
How to distinguish R180 and R200
Apart from the 5 or 6 bolts half shaft, how can I tell the difference between the R180 and R200?
Thanks for any help.
pepsicola is offline   Reply With Quote
Old 10-15-2005, 10:34 AM   #2
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
actual size difference in the pumpkin, and R200's came in a variety of different output shafts depending on the year made, 5 and 6 bolt. .
R200's have been being manufactured since the end of the 70's. The only thing you will find R180's in is 240z's and Suburu's. All Z cars after the 280z(R190) came stock with R200 diffs. As did any RWD IRS multi link suspension car that Nissan built.
New Video
Buy my mounts!
Old 10-15-2005, 11:12 AM   #3
pepsicola
are you 100% sure on this, as I read somewhere on the net that jap spec 180sx do come with R180s. although it's good news for me if what u said is true.
Old 10-15-2005, 11:27 AM   #4
drift freaq
yes, I know my Nissan's . That Japanese spec 180sx did not come with a R180 the R180 is a very old differential. Like I said earlier Nissan has been installing R200's in all their RWD IRS cars since the end of the 70's. Now it having a R200 does not mean automatically that it has a VLSD or LSD.
New Video
Buy my mounts!
Old 10-15-2005, 11:47 AM   #5
PROJECTRB240SX
PROJECTRB240SX is an unknown quantity at this point
Thats not true....
The R180 can be found all the way up to the 280zx in 1983.
Subaru uses the R160 most commonly and in later years use the R180 and R200.
The Nissan 280z never got a R190 it was either a R180 or R200.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
PROJECTRB240SX is offline   Reply With Quote
Old 10-15-2005, 04:28 PM   #6
pepsicola
but still, it applies for my 180sx that it should have a R200 stock, right?
just to make sure so that I am sure that I can fit my HLSD in.
Thanks for the info again.
Old 10-15-2005, 04:33 PM   #7
orion::S14
orion::S14's Avatar
^^^ To make it simple...EVERY S13/S14 came with an R200...including your 180SX.
Some had 5-bolt output shafts, most have 6-bolt. Stock ratios are typically 4.08 or 4.36 (yours is probably the 4.36).
- Brian
www.KA24DEvelopment.com
Old 10-15-2005, 08:28 PM   #8
pepsicola
I did a quick measure on the diff last night, it's only about 18cm in length from left to right on the rear cover. And I just bought a S15 diff, it looks bigger than the one i've got under my car.
Don't know whether it's a visual difference, or it's really a smaller type R180 diff.
Old 10-15-2005, 08:37 PM   #9
drift freaq
Originally Posted by PROJECTRB240SX
Thats not true....
you know what , your wrong , I pulled R200's out of 1981 280zx's. Nissan did stop putting R180's in the cars after the 260z you can argue with me all you want I owned the cars and used to set them up. I would be willing to bet you were either in diapers at that point in life or not even born.
New Video
Buy my mounts!
Old 10-15-2005, 08:41 PM   #10
drift freaq
- Brian
C18DET 180sx's came with 4.36
SR20DET 180sx's and S13 Silvias came with 4.08's
KA24e and KA24DE 240sx's came with 4.08's
New Video
Buy my mounts!
Old 10-15-2005, 10:50 PM   #11
PROJECTRB240SX
You want to bet there are r180's in the 280zx? all the automatics came with a 3.545 R200 upto 1983.
The 280z Had either a r180 for the auto or R200 in the 5 speed.
Before you play the old man do some research. This topic is widely covered on all Z forums. Ohh wait let me guess non of those guys know anything because they aren't uber elite like you, right?
And I can show you my two 280z that Have both the r180 and r200.... Also I've got a buddy with a non-turbo auto 280zx with a r180. The R190 you speak of was never put in any Z car except the 432R (which is truely a R192).
Old 10-15-2005, 10:50 PM   #12
PROJECTRB240SX
Show me one link proving me wrong and I can show you about 500 that will say otherwise.
Old 10-17-2005, 12:08 AM   #13
pepsicola
I took some pictures of the diff last night, and had a close look at it.
I believe that I've got a R180 in there. I've actually got a s15 r200 beside the car, I can see that the r200 is much bigger, beefier.
Here's the link to the pics.
http://members.iinet.net.au/~jinmic/s13diff/
Old 04-28-2020, 04:03 PM   #14
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
bumping this up from the dead.
now need a little help. is this a a R180 or R200 diff
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-28-2020, 04:49 PM   #15
mechanicalmoron
I think the R180 looks ancient, different rear cover shape.
But I (think I) know it's the ring gear diameter. Measure it.
Old 04-28-2020, 05:13 PM   #16
s13silvia123
that's why i'm asking if this diff was one or not. about to pull the trigger and buy it. since i can't measure it. if it turns out to be a R180 i can always sell it to the 280z guys. but the difference is the shape of the diff. looks more like a R200 as well as the rear cover.
Old 04-28-2020, 09:12 PM   #17
mechanicalmoron
Oh, I assumed you had access to it.
If I just saw that in a pile of random manufacturer diffs, I'd assume it was an r200.
Old 04-30-2020, 12:21 PM   #18
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
That looks like a S13 4.08 R200 diff.
The ears on the R180 stick out more because of how narrow the whole pumpkin is.
Oh, and FYI for the info in earlier posts, non-turbo S13 & S14 cars did come with R180 diffs. Not sure if it was only the Euro cars or what, but it's wrong to assume all s-chassis cars came with R200 diffs.
LoSt180 is offline   Reply With Quote
