Old 11-04-2005, 02:08 PM   #1
tammha
tammha's Avatar
tammha is an unknown quantity at this point
Dash light does not work!
I just bought a 240 not long ago and the dash lights does not work. The owner said that it stopped working when he put a new cd player in. What could be causing the problem.
tammha is offline   Reply With Quote
Old 11-04-2005, 02:24 PM   #2
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
does your rear driving lights work at night ? You might want to check the fuses. I had a problem with this a while back with a short in the trunk. Kept blowing the fuse that controls the cluster lights as well as the rear driving lights
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 11-04-2005, 03:45 PM   #3
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
I had a similar problem after a bad CD player install also..
Check fuses, that's probably it
rps13_fastback is offline   Reply With Quote
Old 11-04-2005, 06:40 PM   #4
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
oh my god...
well lets see, there are two obvious places to start, the bulb, or the fuse.
sit down in the driver seat, next to your left leg there is a fuse panel, it might be covered up so you have to look hard, open it up and check the fuses. If you can read you might even be able to narrow down the exact fuse you should check.
now you have to help me out with a problem of mine, I was on my way ot the gas station because my fuel level was on E... my car sputtered and stalled when I was a mile away so I parked my car and went home to post on zilvia and ask if anybody knew what was wrong.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 11-04-2005, 06:44 PM   #5
Rusted_PS13
Rusted_PS13 is making a name for him/her selfRusted_PS13 is making a name for him/her self
yeah, i had the exact same problem, it was a short on the ground side of the 6th secondary AC injector bearing control circuit
Rusted_PS13 is offline   Reply With Quote
Old 11-05-2005, 01:49 AM   #6
reefer1114
reefer1114 is an unknown quantity at this point
bulbs..................?
reefer1114 is offline   Reply With Quote
Old 11-06-2005, 02:01 AM   #7
kenibust
kenibust is an unknown quantity at this point
I had the exact problem with mine after i installed in my new deck. Make sure that your Illumination wire is not hooked up in the CD deck (orange wire). Then in the driver side kick panel there should be a small white box (Timing control unit, TCU). Go to your nearest junkyard and see if your can find one. Should work gauranteed.
kenibust is offline   Reply With Quote
Old 11-06-2005, 02:55 AM   #8
Irukandji
one time i was eating corn nuts and i kept eating and eating and cornuts got stuck in my teeth and i didnt brush my teeth but i kept eating corn nuts and now i have cornuts in my teeth. can anyone tell me whats wrong?
Old 11-06-2005, 04:14 AM   #9
reefer1114
wtf are cornuts?
