Old 11-08-2005, 05:17 AM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
s13 help with ka24e won't start. gots air fuel and spark.
rebuilt the whole damn thing. as in, changed head gasket, and some other gaskets :P so not really rebuild, ok fine, i changed the headgasket.
so now, i have fuel, spark, and air, but the damn thing won't start.
i have the exhaust manifold off, so when i crank it, i see the damn fuel comin out white, like, no combustion.
and i checked for spark, i changed new wires and new spark plugs, and the spark is there, i see it. bosch platinums.
i crank i crank, i crank some more, like, 20 seconds, well, friend cranks, and i push the timing back and forth. not even close to firing up.
checked compression, brand new head gasket, but everything else is origional, head and pistons rings are old. 120 150 150 150
what is the ups! start damnit, help me. i heard i should check coolant and air temp sensors, but damn, it doesnt even get close to startin.
i checked grounds, didnt really know which ones, i only see one near the egr/exhaust manifold tiny little ground, and the other ground is the one near the battery tray, injectors are all grounded to the head.
help me im so sad.
95zilvia is offline   Reply With Quote
Old 11-08-2005, 10:51 PM   #2
95zilvia
help so lonely i r
Old 11-08-2005, 11:28 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
sounds like your dizzy is off by a couple teeth
Old 11-08-2005, 11:42 PM   #4
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
There is a problem with your one cylinder that has the compression of 120. Your cam timing or even ignition timing may also be wrong.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-09-2005, 05:00 AM   #5
monkey7
monkey7's Avatar
monkey7 is making a name for him/her selfmonkey7 is making a name for him/her self
Sounds like your distributor maybe off, just like Neme said. You have to take the oil pump, distributor off and make adjustments.
monkey7 is offline   Reply With Quote
Old 11-09-2005, 06:55 PM   #6
95zilvia
Ok, so I THINK my distributor is off, pretty sure actually.
But anyone else think it's not OK for my compression to be 120/150/150/150
Old 11-09-2005, 07:59 PM   #7
aznpoopy
aznpoopy's Avatar
well
compression #'s l ike that ... its not healthy
it shouldn't keep the car from starting, however.
Old 11-09-2005, 11:04 PM   #8
95zilvia
thats what i thught too.
im gonna try to redo the disctributor and oil pump
any other ideas?
Old 11-10-2005, 08:59 AM   #9
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
Clean your IACV, mine did the same when I changed injector o-rings, just turned over, wouldnt fire. Eventually it just cranked right up.
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
