Old 11-17-2005, 01:05 PM   #1
youngmanvr4
youngmanvr4 is making a name for him/her selfyoungmanvr4 is making a name for him/her self
Help!!!: Working out the bugs on SOHC to DOHC and auto to 5-spd.
First off I just did my SOHC to DOHC swap. Also I did a auto to manual swap. It runs fine (other then on knock sensor..I should get the new one tomorrow). But I am having a couple problems. Just for fyi, I bought the car with no engine in it. Its a 90 and was a auto.
The first thing is the power steering, I for some reason dont have any. Since I didn't have a engine in the car before (like a SOHC one) I didn't have a power steering pump. So I bought one used from a guy on another 240 forum. He said it worked. So I get it put it in and I dont have any power steering. Everything is hooked up. Nothing leaks. I just simply dont have power steering. So what should I do? What should I check?
Second is the shifter, In first, third and fifth it hits the center console but goes into gear. If I put the radio trim in its even worse and wont even go into gear. Why in the world is it doing this? I mean when I'm in first third or fifth and I have my hand on the knob my hand would hit the head unit if I had one in. I know the engine and tranny are mount the right way becuase I have everything bolted down. So why in the world is it doing this?
Ok...thats a pic with the radio trim off and in neutral.
This pic is with the radio trim off and in gear. It does go into gear with the radio trim off. If you look close you can see it is touching.
This pic is with the radio trim on and in neutral.
This pic is with the radio trim on and me pushing the shifter forward. I dont go into gear.
If you need more pics I can take some. Anything to get it to work right
Third is a vacuum line. I got the 4 connected that come out of the throttle body. But their is one more...its to the side of the 4 on the TB. It faces to the passenger fender well (sorta) as to the 4 under the TB face to the front of the car. Where does that vacuum line go?
I'll take a pic of what I'm talking about alittle bit later today. If you need anymore info I'll try my best to awnser. Thanks everyone.
youngmanvr4 is offline   Reply With Quote
Old 11-17-2005, 01:12 PM   #2
ALTRNTV
Strange. Take pics of the console farther away. It looks a bit crooked in the pictures.
ALTRNTV is offline   Reply With Quote
Old 11-17-2005, 04:10 PM   #3
youngmanvr4
Ok...heres the vacuum line I was talking about.
Another angle.
And A pic of my new engine/bay I'm not done. I'm going to make it look nicer then I dose right now. I just want to get it running right first.
And the console. I have them in bigger too if you need to see better.
Old 11-17-2005, 04:56 PM   #4
ALTRNTV
I don't know if it'll make a difference, but is that still the automatic console? The 5spd console might be different, but don't quote me on that. Just a suggestion.
Old 11-17-2005, 05:30 PM   #5
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
I dont think it's the console. It looks like the shifter is on backwards
DP_Michelle G is offline   Reply With Quote
Old 11-17-2005, 05:31 PM   #6
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
on the s13, the auto and manula console piece is the same, minus teh middle part...honestly it appears that the shifter is essentially backward. Take it out and rotate it 180deg and put it back in. Its just held in there with a c-clip.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 11-17-2005, 05:36 PM   #7
ALTRNTV
LMAO. Why didn't I think of that? I think it's the alcohol... puahaha.
Old 11-17-2005, 06:33 PM   #8
youngmanvr4
Ok...I'll try that. My dad put it in. I was working on another something else at the time. So that might be whats up. Though he was the one who took it out too, to get tranny to clear when putting the engine in.
Anymore help with the other questions? The power steering and vacuum line?
Old 11-17-2005, 10:18 PM   #9
sdtouge
sdtouge can only hope to improve
Originally Posted by youngmanvr4
(other then on knock sensor..I should get the new one tomorrow)..
is your knock sensor hooked up? sohc didnt have one and i beleive its on the lower harness, so you would have to hard wire it? unless its on the engine harness then im wrong.
The first thing is the power steering, I for some reason dont have any. What should I check?.
you should make shure you have the little washer where the bolt goes. and that the belt is on lol. the washer is like a tiny spacer, and becuase there are holes in that bolt, its needed for that washer to be there, otherwise fluid might not flow depending on how the bolt is aligned. also after installing the washer you may also want to bleed your power steering. its really simple. jack up the frnot of the car a little bit, turn the steerng wheel lock to lock a few times, refill, turn it lock to lock, refill the resiovior till it stops taking more fluid. then do the same witrh the engine on.
for the shiter, my guess is its on backwards
for the vacuum line, if you cant find out where it goes, either a, cap it off, b, find someone else with a ka24de willing to let you check theirs out. im guessing it goes to that vacuum tube or whatever near the air box, but im really not sure,.
good luck
matt
sdtouge is offline   Reply With Quote
Old 11-18-2005, 04:23 PM   #10
esco23
esco23 is an unknown quantity at this point
can anyone offer help on the crank sensor? i have tried to search but found no info on it while doing this same swap. just trying to cover all bases before i start this.
esco23 is offline   Reply With Quote
Old 11-18-2005, 05:04 PM   #11
youngmanvr4
Well you guys nailed it. The shifter was backwards. Its shifts alot nicer now lol...and goes into gear with out anything. Looks so much nicer lol.
esco, look at pic. Oh and welcome to the forum. I see your new here..as am I.
Old 11-18-2005, 05:11 PM   #12
esco23
that is the camshaft position sensor. i am talking about the one in the bell housing of the tranny
Old 11-18-2005, 05:17 PM   #13
mrmephistopheles
mrmephistopheles's Avatar
Knock sensor is on the main engine harness.
good luck
matt
Find someone with a stock S13 KA24DE setup and check it out. In the meantime, teeing it with the other vacuum lines wouldn't hurt (but blocking it off probably wouldn't hurt either).
Originally Posted by PHLIP
Old 11-18-2005, 05:21 PM   #14
esco23
i used your tech in for sohc to dohc. useing the 95 ka. how did you hook up the crank shaft sensor?
