Old 11-21-2005, 12:26 PM   #1
KarateBoy
KarateBoy is an unknown quantity at this point
So I failed emissions...
My readings were 1.04 for HC and 9.2 for CO
The legal limit for HC is 0.80 and 15.0.
I passed the CO limit by a decent margin but I'm obviously not burning enough fuel.
I ran the test on mid-grade so 93 V-power alone probably won't get me down the extra 0.24 points.
I've been reading that running injector cleaner helps a lot. Does it matter if I pour it in before I tank up or not? I think not as it would all mix together anyway.
I think its also important to not that over the last 2 weeks or so my idle has been getting rougher.
I was standing in line with my car on and not only would the idle flucuate from 500-750 rpm but the car would shake a little? Could it be knocking?
Thanks in advanced
KarateBoy is offline   Reply With Quote
Old 11-21-2005, 02:51 PM   #2
n240sx
n240sx is an unknown quantity at this point
i dont know if you looked at this already, but this may help http://www.zilvia.net/f/showthread.php?t=92585
n240sx is offline   Reply With Quote
Old 11-21-2005, 03:47 PM   #3
monkey7
monkey7's Avatar
monkey7 is making a name for him/her selfmonkey7 is making a name for him/her self
You can do it with
Seafoam!
monkey7 is offline   Reply With Quote
Old 11-21-2005, 05:24 PM   #4
aznpoopy
aznpoopy's Avatar
get some throttle body cleaner and run it through the engine.
or seafoam, same difference.
warm up the car with a good long drive before you go and try again.
edit: it's not knocking, it's probably your IACV. it, along with your entire intake tract, is gunked up with 10+ years worth of dust from the air. clean your filter too if you haven't.
Old 11-21-2005, 06:15 PM   #5
TheTimanator
TheTimanator's Avatar
hahaha
out of curiosity i went and got my car tested. I recently got a new exhaust and cat so I thought i'd give it a shot.
Legal limit CO is 1.2 and i got a 8.50
Old 11-21-2005, 06:21 PM   #6
aznpoopy
aznpoopy's Avatar
wow
you must be running rich as hell.
Old 11-21-2005, 06:34 PM   #7
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
adjust your idle!
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 11-21-2005, 06:54 PM   #8
Var
Var's Avatar
Send a message via AIM to Var
Thanks in advanced
Change
oil
02 sensor
spark plugs
advance timing
if that doesn't work change your cat.
Run your car hard before the test..that helps warm up the cat..and dont turn it off. Dont let the technician turn it off either.
Hi
Old 11-21-2005, 07:11 PM   #9
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
if your emissions are way off, its most likely the o2 sensor
pretty much what 420 said lol
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
