Old 11-21-2005, 12:20 PM   #1
Shri2222
Shri2222 is an unknown quantity at this point
Send a message via AIM to Shri2222 Send a message via MSN to Shri2222
S13 Triple beam projector bulb
Yes I searched and alot came up, i clicked n read them, but 1 problem occured on my search, everyone with the conversion that posted that question had dual beam projectors... I need the projector foglight mine blew out today. Searched 2 forums came up empty i pulled the bulb out, was the weirdest bulb i've seen. I run a parts store i got a larg inventory of bulbs dosn't look like anything I have.. It's not a H3 like the low beam..
91 S13 Coupe CA18DET powered, now with smaller siggy
Shri2222 is offline   Reply With Quote
Old 11-21-2005, 01:48 PM   #2
A Spec Products
A Spec Products's Avatar
http://www.zilvia.net/f/showthread.php?t=38783
Triple Projectors:
Lowbeams - H1
Highbeams - H3
Foglamps - H3c
hit me up i can get you some koito, the good stuff
A SPEC PRODUCTS CORP
Old 11-21-2005, 01:53 PM   #3
Shri2222
Triple Projectors:
Lowbeams - H1
Highbeams - H3
Foglamps - H3c
Thnx alot, i been too 2 auto suppliers not even autoshops, even the suppliers were stumped gave them the bulb, told them where i worked and said i can't figger this one out. I was about to get a H3 and sodder the prongs from the old one to the wires of t he H3..
Old 11-21-2005, 02:35 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
Triple Projectors:
Lowbeams - H1
Highbeams - H3
Foglamps - H3c
Thanks Logan - glad to see the search function isn't broken.
Originally Posted by PHLIP
Old 11-21-2005, 02:41 PM   #5
A Spec Products
Haha fo sho.
Its more like the Archive and FAQ section isn't broken
Even better than searching, new accounts should be locked until they spend at least 1 hour in there
So much good info.
Old 11-21-2005, 03:23 PM   #6
mrmephistopheles
yeah... wish we had an easy way of doing that.
Old 11-21-2005, 03:49 PM   #7
cyanide
cyanide is an unknown quantity at this point
Send a message via AIM to cyanide
somewhat off topic, but pertaining to the triple light projectors --- does anyone know where i can get a harness that plugs into both the low beam and high beam headlights? one of my triple projectors came with one, the other did not. this is the harness that plugs into the stock three prong plug that comes off the popup headlights.
cyanide is offline   Reply With Quote
Old 11-21-2005, 03:49 PM   #8
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
If you want to get one local, the Toyota dealership carries them. They came on some late 90s foglights. A guy came into our store looking for some and i was the only person who knew what they were because i wanted to try and get some for some friends. Not even a european warehouse had them. He later came back and told me the toyota deal carries them instock.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 11-21-2005, 03:54 PM   #9
cyanide
is it possible you can get the part #?
Old 11-21-2005, 04:26 PM   #10
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
I dont know why your having so much trouble. I picked up a set of silverstars from autozone and they work like a mofo. Bright as hell and easy to wire up. Easily better than what I had before.
Bulbs look like this:
Housing looks like this:
The tab on the housing is negative or ground. The wire/tab coming off the light is pos.
Just get a set of those and hook them up....they are nice and bright...you wont be disappointed.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
Old 11-22-2005, 08:39 PM   #11
Shri2222
I have a projector FOG, That bulb you posted is a H3 with a pig tail.. My bulb has no pig tail its a H3C It has 2 prongs.
Old 11-22-2005, 09:50 PM   #12
Yuri
Ghost of Zilvia past
Yuri's Avatar
Yeah, but you can replace the dual prong with a "pigtail" bulb. Look on the actual headlight housing for the ground terminal. It is exactly as shown in the pic above. Run the pigtail into the positive slot and run a lead from the negative slot to the ground on the housing. I replaced all my dual prongs with pigtail silverstars when I had projectors. I have non projectors now. So much more light
Yuri is offline   Reply With Quote
Old 11-23-2005, 08:27 AM   #13
Shawn_of_the_Dead
exactly....just convert it to the reg. H3. I grounded mine out with a 6 inch neg wire off the housing tab straight to the metal behind the lights. H3c's are much harder to find and this is so easy to do. I have a better light output that before too.
Oh, and incase you can't tell I also have PROJ. fogs. Hence the reason I chimed in to assist.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Old 11-23-2005, 09:51 AM   #14
Shri2222
ah. nce thanks for the heads up.
Old 11-23-2005, 04:07 PM   #15
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
And a nice little write up (diff car, but same idea):
h3c to h3 conversion
brokeAs240sx is offline   Reply With Quote
Old 11-25-2005, 06:03 PM   #16
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
I acutally have a H3c Kiotto or whatever company called that I bought for like 40 bucks, if you want it I'll send it to you for free, just pay me shipping, I went D2S.
240meowth is offline   Reply With Quote
