![]() Well I was pleasantly surprised. At stock boost no boost controller I made 204 whp. 193 wtq. Only mods are a z32 maf, clutch and 3 inch turbo back exhaust. timing was left stock. 2 bad news things- i blew my water pump while I was on the dyno. (my guess is that there was air in the system) other bad thing- my car after I shut it off when its warm it doesnt want to start for a few minutes. weirdest thing though. If i unplug one or two of my injectors it will start sooner. hmmmmmmmmm. I must say I am upset i didint get to take it for a beat run but hey its meant to be. Im still missing a few things though so this is for the best. anyone else suprised by these numbers? i definatly thing 230-235 whp is possible at 14 lbs.
Black S14 Base Model Converted to SE w/ extra goodies. |
![]() Join Date: Apr 2002
what are you using to control the z32 maf? also, are you running the the factory side mount intercooler?
post the dyno sheet!
89 S13 hatch/////98 Subaru 2.5RS |
your shoud replace your coolant temp sensor...the sensor is telling the ecu false info and it's dumping a ton of fuel, which would explain why it starts sooner when you unplug some of the injectors. check the ecu for codes, check the wiring and then check the sensor. my stock sr at stock boost with 3" back made 200whp and 194wtq. good luck with everything...
![]() Join Date: Nov 2004
i made 213rwhp and forget the torque numbers but i was running stock except for 3inch downpipe, no cat, and 3 inch apex'i n1 cat-back, greddy fmic and safc II and 10psi.
![]() Join Date: Aug 2002
TheTimanator " what you useing to control the z32 maf"
either way that motor is not stock, unles u mean stock block. that seems a little high in the #'s for lacking a front mount, do you have a water sprayer?, AFC to increase the fuel to make that kind of power at stock boost? I put down 184hp, filter, downpipe, high flow cat, 3in exhaust. 20hp from a z32 maf? I know with safc, frontmount it can make 20whp more then my setup. but just a maf itself?
#9 | |
from what i understand you don't actually gain power from running a Z32 maf it's just not limited as much as the factory maf
#10 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
is it that hard to believe that he has a good strong running motor? lol. look at the location, MA. It's cold up there.
My friend with a WRX had a stock top mount IC. It heatsoaked like a bitch durring the spring and summer just city driving. Now, the IC is ALWAYS icey cold.
HouseBuyers365.com Quote:
![]() Join Date: Jun 2003
What kind of dyno machines were these run on?
I know that Mustang Dynos and Dynojets have different readings with the latter having higher numbers. |
#13 | |
#16 | |
from Canada, eh!
![]() Join Date: Sep 2001
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#17 |
i really didnt tune much. i only used the e manage to control the z32 maf. the a/f is at the factory settings as is the timing.
#18 |
![]() Join Date: Jan 2004
Damn nice #'s
My friend did 200hp and 201tq on a stock s13 blacktop, on 12psi, exhaust and intake. What do you guys think a stock s15 sr, on 8psi, exhaust, dumppipe, intake, and frontmount would put down? I am about to drive it this afternoon for the first time so I cant make a guesstimation just yet. I dont even know what its boosting, but I am predicting 8psi.
#19 |
![]() Join Date: Sep 2004
Get pics for the Volvo intercooler!
I assume it's from a 740, i dont know about ~1985 240gl-t's but i do know know about half the 740 turbo's dont have an intercooler. which is messed up from a technical standpoint. btw 740 turbo's are a good source for used decent size oil coolers ![]() |
#20 |
damn i got to take pics. when I tell people there like o you just have a volvo intercooler. then they see it and they think its sick!
