Old 12-07-2005, 04:45 PM   #1
gpeele
gpeele's Avatar
gpeele is on a distinguished road
S15 helical diff grinding
this is a s15 helical diff installed in a spare s13 non abs pumpkin with the correct output shafts and brand new shims, bearings and seals. all installation was done by a shop sometime ago but the shop has since closed.
just today i had the pumpkin swaped out with my stock one and it was making a loud grinding noise, like loud enough to be heard when the rear is jacked up and the wheels spin freely when the accelerator is pressed. when on the road the noise is much louder and reverbs through the car. i cant take it back to the original shop for obvious reasons, so what could be the problem, bad shims, crappy fluid (75w90 gear oil is in there now). are helical lsds themselves known to go bad? any help will be appreciated.
thanks.
gpeele is offline   Reply With Quote
Old 12-07-2005, 04:52 PM   #2
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
I have yet to hear S15 lsd go bad... they are durable and dont wear out like clutch type. My best guess they screwed up one of the bearigns ... hard to tell without looking at it.
Where in Chesapeake are you? I may be interested in getting that from you if you dont feel like messing with it. Give me a call 6153421
Al_S14 is offline   Reply With Quote
Old 12-07-2005, 08:25 PM   #3
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Bearings or shimmed improperly; both are easy to fuck up.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 12-07-2005, 10:17 PM   #4
gpeele
gpeele's Avatar
sorry man, not really interested in selling the diff i just want it to work. i guess ill have to take it by a transmission shop and see if they can tell me whether its the shims or bearings, im just glad to hear that the lsd itself shouldnt be the problem.
thanks for the replies.
Old 12-08-2005, 02:26 PM   #5
wootwoot
No but the lsd could be ruined if shimmed improperly...
Old 12-08-2005, 06:40 PM   #6
96240sxSE
96240sxSE is an unknown quantity at this point
Have a shop(a good one) take a look at the wear patterns on the teeth of the r&p. The wear pattern will tell a good tech if the diff was shimmed improperly. If you are lucky, you may just have to buy a new r&p, not the entire assembly.
96240sxSE is offline   Reply With Quote
Old 12-08-2005, 06:46 PM   #7
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
take it out, and reinstall it with new shims and bearings
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 12-08-2005, 08:40 PM   #8
kandyflip445
kandyflip445's Avatar
^^^What he said. Inspect for damage. When you drain out the fluid into a pan run a magnet through it and see just how much metal there is. If there is a shitload then you need to inspect everything. If there is minimal metal then you should still check but it's more likely to be ok.
My 240 vBgarage
