Old 12-13-2005, 05:56 AM   #1
aznxplayer
aznxplayer can only hope to improve
Send a message via AIM to aznxplayer
s13 axle grease.
hi, i got a new axle in the mail, and when i got it the end cap was off, this is a rear axle btw. anyhow, i put the cap back on and forgot to re pack the the axle up with grease, should i pop the cap off and repack it? there was still grease in it, but i cant seem to get the cap off.
is it super bad to run on it if the axle end isnt packed?
thx.
black 91 hatch R.I.P
black 90 hatch sr20 R.I.P
black 90 hatch!!!!
aznxplayer is offline   Reply With Quote
Old 12-13-2005, 07:02 AM   #2
andrewmp6
andrewmp6 can only hope to improve
i would make sure its fully packed or youll have problems do you mean the rubber boot over the joint look it over make sure theres no holes in it
andrewmp6 is offline   Reply With Quote
Old 12-13-2005, 10:31 AM   #3
s13driver
s13driver is an unknown quantity at this point
if i were you, i would pop the end cap off and put enought grease on it.. and poping it out is easy, all you have to do is put the axle on vise and then push the rod against the cap hard, and it will pop out. at least that's how it did it.
it is so hard to educate the uneducated.
s13driver is offline   Reply With Quote
Old 12-13-2005, 07:21 PM   #4
skiboard06
skiboard06 is an unknown quantity at this point
def fully pack it or you will be replacing it quite soon and going thru the same ordeal
skiboard06 is offline   Reply With Quote
Old 12-14-2005, 12:17 AM   #5
aznxplayer
kk thx....ill try poppin the cap off. hope it works hah.
black 90 hatch!!!!
