Old 12-28-2005, 08:32 PM   #1
91ka
91ka is on the path to ruin91ka is on the path to ruin
s13 how do you check for oil pressure?
when i turn the engine on in the morning, it takes longer for the oil check light to go off. yesterday i had a canyon run, and today when i turned engine on, it almost took 8 sec's for the oil check light to turn off...
ive heard that if oil pressure is low the tensioners that keep the timing chain tight are operated by oil pressure so if your oil pressure is low then the tensioner will not be working properly hence your chain will flap around and hit the guides.
would oil starvation be resolved with a new oil pan? and how do i check for oil pressure? nevertheless even know that its the oil pressure.
91ka is offline   Reply With Quote
Old 12-28-2005, 08:50 PM   #2
projectRDM
projectRDM's Avatar
Oil pan won't do anything unless your current one is dented in. A new oil pump will fix any low pressure problems if the drive gear is worn or damaged, but you'll need to check it with a true gauge right at the sender to verify pressure. After that, check the tensioners for excess wear/play.
FORMERLY R240NA
Old 12-28-2005, 09:31 PM   #3
91ka
"true gauge right at the sender?" visual plze
Old 12-28-2005, 09:32 PM   #4
91ka
Old 12-29-2005, 01:10 AM   #5
91ka
would i test this while the cars running? what psi should i be reading. i remember somewhere on this forum where fsm said 11psi plus during idle (when the engine is warm) is normal.
Old 12-29-2005, 02:32 AM   #6
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
you need to get an oil pressure gauge and test it while the cars running. 11-15 is normal for warm at idle, and it progressively goes up as your revs go up.
DJPimpFlex is offline   Reply With Quote
Old 12-29-2005, 02:56 AM   #7
drftone
drftone is an unknown quantity at this point
make sure ur oil pan has not dent
drftone is offline   Reply With Quote
