Old 12-28-2005, 07:04 PM   #1
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
Erratic timing issue sr20
When i attemp to read the ignition timing on my sr it is very stable at 15 btdc while the motor is cold but when it goes into closed loop,"warmed up" the timing jumps all around at idle. Also are you supposed to set the timing at idle or are you supposed to hold rpm at 3000?
RedtopTech is offline   Reply With Quote
Old 12-28-2005, 07:08 PM   #2
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
ok well first, nice one on the tripple posts. Second, when the car gets warmed up it goes into open loop, not closed loop. Did you unplug the TPS? What motor?
DJPimpFlex is offline   Reply With Quote
Old 12-28-2005, 07:21 PM   #3
projectRDM
projectRDM's Avatar
Why don't you try asking us three more times, I don't think we got it yet.
FORMERLY R240NA
Old 12-29-2005, 05:11 PM   #4
RedtopTech
RedtopTech's Avatar
i dont understand why you goes refuse to help. Is there a rule about #'s of posts. If there is then i am sorry. How else do you expect me to figure it out unless i make sure that enough people here my problem.
Old 12-29-2005, 07:35 PM   #5
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
kinda funny how your username reflects tech... but anyway, i assume you have a redtop? if so all you should do is make sure the car is warm, then unplug the TPS sensor, then time the motor, then plug the tps sensor back in... pretty sure that is the correct way to time it
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 12-29-2005, 09:17 PM   #6
DJPimpFlex
DJPimpFlex's Avatar
basically right, but you have to race the motor up pto 3k 3 times with the tps unpluged
Old 12-30-2005, 12:25 AM   #7
SoSideways
SoSideways's Avatar
Why are you working on your motor without the FSM? I'm pretty sure you're gonna ask what an FSM is too, so I'll just type it out for you now as part of the spoon feeding.
It is called FSM because it stands for Factory Service Manual. It will be your bible for when you work on your car. Only if you don't get the results that the FSM says you should have, should you post here asking about it.
Why am I bashing you? Because it's obvious you have not even looked into the FSM, when that whole procedure was outlined for you.
Shit, if you would have searched on FA or here, you would have found the answer, as you're not the only one that has ever tried to time a friggin SR godamned motor.
I need to stop before I kill someone. Sorry but I am posting in a bad mood.
