Old 10-28-2005, 11:25 PM   #1
Lava
Lava is an unknown quantity at this point
180sx brake question
what size are the 180sx jdm calpiers?
are z32 30mm calipers better?
i heard 180sx calipers are 30mm too
can someone plz tell me
Lava is offline   Reply With Quote
Old 10-28-2005, 11:34 PM   #2
mr_240sx
mr_240sx's Avatar
have you tried searching? this forum is full of great stuff, you just gotta search to find your answers!
mr_240sx is offline   Reply With Quote
Old 10-29-2005, 06:43 AM   #3
g6civcx
g6civcx's Avatar
JDM 180SX 4-lug brakes are mid-90s Altima rotors and Maxima pads.
Old 10-29-2005, 11:47 AM   #4
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
25mm is the size , next time search , its all here
New Video
Buy my mounts!
Old 10-29-2005, 12:44 PM   #5
FRpilot
FRpilot's Avatar
by the way you formated your questions, i dont even think know why one caliper would better than another. 30mm is the space between the caliper that allows clearance for the rotor. generally, it doesnt matter much, but a slightly larger rotor widthwise will offer slightly better heat dissapation and cooling.
you would want to look at how big the caliper is and how many pistons it has. if the pistons are bigger and the caliper takes up more space on the rotor, then it should allow more of the rotor to be 'clamped' down when you apply the brakes which would help your car stop faster..
as to which calipers would be better, it depends on what you are using the car for. it is up to you. if you are just trying to be cool, then get z32 calipers since thats what ppl usually get . 180sx brake rotors are only slightly bigger than stock 240sx rotors. most ppl find that q45 brakes are adequate for what they use the car for. if you want to go bigger, go with z32 calipers, or if you want to go all out, go get some 3000+ big brake kit with 6pistons, 13inch rotors, etc by Endless, project mu, etc.
FRpilot is offline   Reply With Quote
Old 10-29-2005, 05:14 PM   #6
NismoSilvia270R
NismoSilvia270R's Avatar
NismoSilvia270R is an unknown quantity at this point
Send a message via AIM to NismoSilvia270R
this is almost true, except i dont think the jdm 180sx came with the misalignment that my maxima/altima combo has.
i want to argue EVERYONE that says its "jdm", until i see a jdm 180 with overhang.
+1 anyway
NismoSilvia270R is offline   Reply With Quote
Old 10-29-2005, 10:01 PM   #7
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
explain your situation please.
my JDM Silvia rotors are warped and i need to find replacement soon. I need to know whether or not the Altima rotors are the same.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 10-30-2005, 01:19 AM   #8
NismoSilvia270R
if you want me to explain the situation, its as such:
http://www.zilvia.net/f/showpost.php...6&postcount=29
common to all us maxima conversion guys.
note in the first picture that you can see about a 1/8" of the pad's fristion surface overhanging the rotor. not a huge deal, since it's still an upgrade form stock, but a larger rotor would be cool.
Old 10-30-2005, 02:47 PM   #9
Silverbullet
sorry, i can't exactly see whats wrong in the pictures. what do you mean over hang?
HouseBuyers365.com
Old 10-30-2005, 04:03 PM   #10
NismoSilvia270R
just for comparison
thanks tastyratz
Old 10-31-2005, 02:31 AM   #11
Lava
i wanna do a 5 lug brake swap
i think i am goin to buy the jdm 180sx hubs or wutever
and get z32 ebrakes and calipers rotors etc
is that a good idea or any suggestions?
Old 10-31-2005, 04:55 AM   #12
NismoSilvia270R
180sx=4lug
you can do "z32 brake swap" and not have the 5lug (drill rotors).
or get the brakes AND the 5lug swap.
i like the maxima deal cause it doesnt have wheel fitment issues and is noticeably larger with more power. also money was a huge factor. i did the whole conversion with ceramic pads, brembo rotors and stainless braided lines for 200.
if you have money go for 300zx brakes.
Old 10-31-2005, 02:42 PM   #13
Silverbullet
oh ok, i see now, thanks Nismosilvia270R. Is this the problem with the Altima rotor not being the right size or the Maxima caliper being slightly different?
HouseBuyers365.com
Old 10-31-2005, 03:30 PM   #14
NismoSilvia270R
i think its the caliper's bolt alignment, but ive never seen a jdm 180 caliper so idk for sure.
search for all the threads about this. theres at least 5 threads that have EVERY nissan rotor measured in diameter and width. offset=no dice
Old 01-01-2006, 08:11 PM   #15
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
I can explain this:
First some facts:
1) 180SX uses a 280mm x 26mm diameter rotor, the Altima/Maxima/P11 G20 use a 280mm x 22mm diameter rotor
2) 180SX does not share the same caliper with the Maxima/Altima/P11 G20.......the 2 bolts that attach to the knuckle are of equal distance and will bolt up but the distance of the ears (mounting tabs) from the centerline of the axle are different specs between teh 180SX and Maxima/Altima/P11 G20 or basically differnt between FWD and RWD.
3) The proper rotor to use beside the JDM 180SX 4 lug rotor will be to use a 90 Z32 NA 280mm x 26mm diameter rotor and redrill to 4 lug or if your not 5 lug.
CHARLIE2020 is offline   Reply With Quote
Old 01-01-2006, 09:35 PM   #16
CHARLIE2020
Front calipers excluding B13/B14 chassis but including P10/P11 chassis:
When you you mount a FWD caliper onto a RWD car you gain a few millimeter so you end up with pad overhang.
When you try and mount RWD calipers onto a P10/P11 chassis it wont fit becasue the mounting tabs are different and teh only way to make them fit would be to lessen the diameter of teh rotor itself a few millimeters.
Old 01-01-2006, 10:31 PM   #17
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Originally Posted by CHARLIE2020
I can explain this:
First some facts:
I dont know how I missed this before but I'm irritated I did. Have you personally tried the 1990 z32 n/a rotor or this is just speculation?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 01-01-2006, 11:26 PM   #18
CHARLIE2020
I took measurements, it will work 280mm x 26mm is the correct diameter and width.
Old 01-23-2007, 09:51 AM   #19
cotbu
cotbu's Avatar
Just thought i'd add,
You can use the sentra ser rotors to fix that 5mm gap problem. SER years are 00-05 IIRC.
Old 01-23-2007, 10:42 AM   #20
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
I have the jdm 180sx calipers and 5 lug, and I use pads and rotors for a 95 maxima and have no overhang problem.
Kouki is offline   Reply With Quote
Old 01-23-2007, 11:36 AM   #21
cotbu
cotbu's Avatar
I don't doubt you, but for those that are four lug the ser rotors are a direct swap. I have the JDM caliper, rotors and 95maxima pads. It's time for me to either step-up or shut-up. So I found the 11' ser rotors. Haven't tried them yet but...time will tell. I don't have the overhang either, and don't want it.
