right now i have p215/60r16's on my car i can get free used
p225's in same size would it be ok to put these on? i figure 10 mm isn't gonna make much of a difference...so is this a bad idea?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>? |
10mm isn't THAT big a deal, but it's nice to have the extra traction; generally moving to larger (wider) tires is seen as a performance mod, unless they're some shit rubber. What's stopping you!?!? If I had free 205s to replace my 195s I'd jump on 'em straight away! Heck if I could squeeze 215s onto my 6.5 (or 6"?) stock steel wheels, I'd do it!
Basically, go for it unless it's a bad/cheap/damaged set of tires. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> Otherwise, you could just switch the rears to 225 and keep 215s up front. BTW isn't the 215/60 R16 a little big? as in, doesn't the huge sidewall look kinda funny? I think the "proper" 225 size should be 225/50/ 16, or at least 225/55 16... but 225/60? Just sounds kind of like a big sidewall.
Instagram: @SX180HKG |
if you have the oem 16x6.5 wheels i would recommend against it. a 225 section width should be complimented with a 50 aspect ratio. and 225 is too big to put on 6.5 wide wheels. how do i know? i did it. yes it will go on the wheel, and no it will not be damaged, but handling will not be optimal. i only had 225's on a 6.5 for a while because i knew i was going to get 7.5 wide wheels eventually. and even then, 8 inch would be better with 225's.
I am running 225/50/16 Toyo Proxies FZ4 all around and they are fine on my 7" rims. They fit the rim nicely unlike my friend with the same tires squeezed onto a 6.5" rim there is a hella lot of sidewall sticking over the lip.
Quick tire lesson in case you don't know how to read a tire
195/60HR15 87H -- stock size for an s13 195 - width measured in mm 60 - Height as a percentage of width 60% X 195mm = 117mm sidewall H - speed rating R - radial tire 15 - rim size 87 - weight rating H - speed rating according to my calculations (unless your stock tire size is different than mine, ie s14) the proper upgrade sizes would be as follows 205/55r15 215/55r15 225/50r15 205/50r16 215/50r16 (this is slightly tall) 215/45r16 (slightly short tire) 225/45r16 anyway, you get the idea. for a better representation of what happens, go to this web page: Turbo! Tire Size Calculator
"It's not how you stand by your car, it's how you drive your car. You better learn that." Winning comes only after preparation. If you don't prepare so you can win then you are inadvertantly preparing to lose. Drive it like you stole it! |
