Old 01-12-2006, 04:55 PM   #1
reverend_sean
reverend_sean's Avatar
reverend_sean is an unknown quantity at this point
Clutch noise/squeal
Ok, I did a ton of searching (here and sr20forum). I just wan't some confirmation from people. I have been getting a light grinding noise when ever I push the pedal down. Accidentally slipped the clutch a little hard last night and now it is a LOUD squeal/scrape sound from the bell housing. Whenever I engage and disengage the clutch I smell burning clutch, so it is obviously not disengaging totally. There is now about 1" of slop at the very top of the pedal range, it wasn't there before last night. No leaks at either slave or master cylinders. My question is could it be anything other then the TO bearing? the car is a redtop s13, exedy stage 2, and I removed the "box" from the clutch line. Any input? THANKS!!
'89 S13
reverend_sean is offline   Reply With Quote
Old 01-12-2006, 05:22 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
Either way you're going to have to pull the tranny to fix it. Take it off, see what's broken and replace.
Old 01-12-2006, 05:33 PM   #3
reverend_sean
Yeah, it is already half way there, just want to have any/all parts ready.
No garge + January + Broken Stuff = Sucks
'89 S13
Old 01-12-2006, 06:23 PM   #4
aznpoopy
aznpoopy's Avatar
definitely sounds like a t/o bearing to me. however, t/o bearing doesnt usually cause a slipping clutch or slop in the hydraulics... at least not in my experience. what it does do is grind a groove into your pressure plate teeth. so you need a new t/o and pressure plate at least.
if you want to be absolutely sure you'll be able to get it all done in one sitting, just do the full clutch job. have a flywheel ready to go (so you dont have to leave the car sitting when you take it to get resurfaced). bring spare slave cylinder, clutch line and maybe even a spare clutch fork. dont forget brake and tranny fluid.
Old 01-12-2006, 09:56 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
Well what if you buy the wrong thing, and then you've spent money on something you don't need.
Old 01-12-2006, 11:52 PM   #6
g6civcx
g6civcx's Avatar
Did you check the pedal assembly itself? Maybe the pedal is coming off the mount and causing you not to disengage it entirely.
Old 01-13-2006, 12:55 AM   #7
Phlip
Yes, I look like that
Phlip's Avatar
I had a similar problem with my old S14 on 2 occasions:
1. Pressure plate died a violent death, 2 fingers were broken off of it
2. The "fork" thingy holding the TO bearing died an even more violent death.
... stock clutches suck.
Weirdo
And I write too!
Old 01-13-2006, 01:41 AM   #8
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
i had the same problem...
solution replace throwing out bearing.
sblack13 is offline   Reply With Quote
Old 01-13-2006, 11:46 AM   #9
reverend_sean
TO bearing is on the way from courtesy. I'm going to hope that is all I need? Very 'eggs in one basket' approach! Thanks for all the input
'89 S13
Old 01-20-2006, 01:05 PM   #10
reverend_sean
TO bearing seized and ruined my 4k exedy PP. Oh well, gotta pay to play!
'89 S13
