Old 01-14-2006, 12:04 AM   #1
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
stupid exhaust leak question
when you have a leak from the manifold to the head its got that tapping sound right? or would it not matter?
i just installed a header i got from a friend and there is this loud exhaust leak i cant find... sounds like its blowing through the thin metal gasket on the cat. sorry for the stupid question flame away...
also is there a silicon sealant for exhaust or would any high temp stuff work? its just for testing out certaint areas..
SR240DET is offline   Reply With Quote
Old 01-14-2006, 03:32 AM   #2
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
my ka had major exhaust leaks from the manifold and yes it made a clicking like noise..
dvdevo is offline   Reply With Quote
Old 01-14-2006, 08:06 AM   #3
g6civcx
g6civcx's Avatar
A quick way to check for exhaust leak is to stuff a rag into the tailpipe and completely plug it up. If the car pushes your rag out or stall, you don't have a leak. If the car is running just fine, then the exhaust is leaking from somewhere.
You probably have a leaky gasket or cracked manifold. There really isn't anything you can put on. You just have to replace the faulty part.
Old 01-14-2006, 09:10 AM   #4
S14DB
AFC #1
S14DB's Avatar
Get new gaskets and spray this crap on the surfaces before you bolt it together:
http://www.permatex.com/products/pro...&item_no=80696
Old 01-14-2006, 10:54 AM   #5
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
that permatex copper stuff works good...but be warned. its kinda a bitch to scrape that crap off if you ever take the parts off again since you have to reapply it. scraping it off my testpipe today, meh..
papershot is offline   Reply With Quote
Old 01-14-2006, 01:50 PM   #6
S14DB
AFC #1
S14DB's Avatar
Razor Scraper FTW. The paste really sucks dick. But I find the spray easy to take off with a razor.
...and you're just going to spray more on.
Old 01-14-2006, 11:36 PM   #7
SR240DET
nice... thanks for the help guys
