Old 01-24-2006, 12:39 PM   #1
sr_sil80
sr_sil80 is an unknown quantity at this point
s13 S13 vs. 180sx hood latch
Is there a difference beween the S13 and 180sx hood latch handle?
I assumed they'd be identical, especially since the S13 front end hood bolts right on.
However, I put on an PS13 ARC cooling panel (on a sil-eighty) and the hood hinge doesn't clear.
I temporarily tweaked the hood hinge so everything works now, but is there a difference?....If not, any ideas why it didn't clear?
Should I buy a hood latch handle from a S13 or 240sx Coupe?
Any ideas????
sr_sil80 is offline   Reply With Quote
Old 01-24-2006, 12:51 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
The hinges are at the back of the hood and should have no effect on a cooling panel.
Old 01-24-2006, 12:55 PM   #3
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
just to nitpick, both the silvia and the 180sx in this case are S13's
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 01-24-2006, 01:39 PM   #4
sr_sil80
I wasn't referring to the hood hinge, now that you mention that, haha.
I am referring to the little handle/latch that you use to open your hood, which should sit in the hole of the cooling panel.
A 180sx is not an S13, regardless of the situation. Sure parts can be interchangeable and the chassis is the same, but they're not the same in any case....just to nitpick
Old 01-24-2006, 03:03 PM   #5
projectRDM
projectRDM's Avatar
They're the same, all S13s are S13s, whether it's PS, RPS, etc.
FORMERLY R240NA
Old 01-24-2006, 06:30 PM   #6
TheTimanator
TheTimanator's Avatar
holy misinformation batman!
S13= chassis code
silvias, 180sx, and 89-94 240sx's have the same chassis.
so...
S13= silvias, 180sx, and 89-94 240sx's
Old 01-24-2006, 07:41 PM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
S13= chassis code
so...
sr_sil80= pwned.
Don't act like you know car names and chassis codes when you don't.
Depending on the motor on your car the chassis code differs. But I don't feel like listing them.
Old 01-24-2006, 09:04 PM   #8
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Well if we went to get super technical...
RPS13-180sx,200sx, 240sx FB
S13-Silvia and 240sx coupe
=P
But are you talking about the cable for the hood latch not clearing properly?? If so that could be because on the JDM dealys ofcourse the hood latch cable would be coming from the other side...I think I understand?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 01-24-2006, 09:09 PM   #9
DriftSpecial180
DriftSpecial180's Avatar
DriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura about
All the guy wants to know is if the hood latch is located in the same spot depending on the the front ends. Although the chassis are the same, the hoods ARE INDEED different. Now, let's ease up fellas.
I'm not hasslin any individual nor saying any individual is correct or incorrect.
DriftSpecial180 is offline   Reply With Quote
Old 01-24-2006, 09:47 PM   #10
TheTimanator
http://www.zilvia.net/f/showthread.php?t=29145
the hoods are definately different but I have never heard of anyone having to change or modify the hood latch when doing a silvia conversion....
your car could have been in an accident causing the latch to be bent a little, which would kinda make sense since you were able to "tweak" it and make it work.
Old 01-24-2006, 11:34 PM   #11
Andrew Bohan
nope that's wrong too
s13 as class of chassis codes means all 89-94 silvia, 180sx, rwd 200sx, and 240sx
s13 as a specific chassis code means 89-90 (ca18de or ca18det powered) coupe
this has all been covered many times
sr_sil80, you can avoid a lot of trouble if you just call it an s13 silvia, as people here tend to get kind of picky
Old 01-24-2006, 11:37 PM   #12
sr_sil80
I had the same belief as wootwoot, but if i'm wrong, then i'm wrong.
Basically, I have a RPS13 (180sx) w/ a Silvia PS13 front end.
I got a hold of an ARC Radiator cooling panel,...the cable is fine, and the Silvia S13 hood closes w/ no problem. However, the latch handle doesn't clear the cooling panel. I had to tweak the handle to open the hood in order for it to clear.
My question is,...Is there a difference between the RPS13 and the PS13 hood latch/handle assembly?
If you don't know, then there's no need to respond.
I will figure it out soon enough when I find a PS13 hood release assembly, but until then I though someone on here might know and could save me the trouble of finding one if i don't need to.
I was trying to be as clear as possible, but I had a feeling the chassis codes will cause some confusion,...haha
...Timanator, thanks for that link...cleared up some of the confusion for me!
Old 01-24-2006, 11:40 PM   #13
Dousan_PG
Dousan_PG's Avatar
you dont have a RPS13
look at your vin plate.
Aaron
Pink GodziRa
Old 01-24-2006, 11:56 PM   #14
sr_sil80
My vin plate has NOTHING to do with the topic of this thread and doesn't help me out at all.
How do go about telling people what they have/don't have w/o actually knowing.
Old 01-25-2006, 12:30 AM   #15
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
He's talking about the VIN plate on your firewall. Also, you should tweek your hood latch to make whatever mods neccessary to operate your hood. I don't believe there is any difference.
As long as you can click your hood closed, I don't see a need for concern.
Old 01-25-2006, 12:52 AM   #16
Pank
Pank's Avatar
holy SHIT i did not mean to start a derail that big.
Hope you got your hood stuff sorted out!
Old 01-25-2006, 01:14 AM   #17
Andrew Bohan
vin plate will tell you explicitly what chassis you have. there's a 99.9% chance you have a US market 240sx fastback. in that case you either have an RHS13 or an RMS13. it says that right on the vin plate.
that's how dousan knows you don't have an RPS13.
if you actually do have a jdm 180sx, then dousan is wrong. but i doubt it.
Old 01-25-2006, 08:07 AM   #18
andrewmp6
andrewmp6 can only hope to improve
usdm is a rhs13 i believe shim the latch or cut the cooling panel or you might not have the front end straight
andrewmp6 is offline   Reply With Quote
Old 01-25-2006, 11:53 AM   #19
Dousan_PG
Dousan_PG's Avatar
oh btw you dont need to change hood latches both are same
Aaron
Pink GodziRa
Old 01-25-2006, 03:47 PM   #20
sr_sil80
cool, thanks Dousan!
I figured they were the same, and I figured someone on here would know more than me, which is why i asked in order to save myself the trouble of tracking down a jdm "PS13" silvia hood latch.
btw, just to point it out, i read through what everyone said again for like the 10th time. and I agree w/ most of you and realize what i said may have threw a lot of people off. I didn't really get my questions answered in the detail that i would've liked as the thread got side tracked.
But I noticed I never mentioned anything wrong, b/c technically I said a 180sx isn't a S13...in reality it is a RPS13 and nothing is a S13 except for the '88-'90 S13 Silvia CA18DET, everything else has its own code.
I could really care less though, but I could see where you're all coming from, and thanks for all this information/confusion/criticism
Old 01-25-2006, 03:58 PM   #21
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
RHD and LHD latches are different. The cable comes from the opposite side of the car, but I don't think that should affect how a cooling panel would fit.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 01-25-2006, 04:26 PM   #22
Dousan_PG
Dousan_PG's Avatar
nah
all s chssis is s13
doesnt matter what motor
chassis is the same
the R is fstbck model
the P is for SR20DET
Aaron
Pink GodziRa
Old 01-25-2006, 11:19 PM   #23
Pank
Pank's Avatar
Thank you dousan, i knew i wasnt wrong
