Old 01-25-2006, 08:07 AM   #1
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
Pulsing Clutch....what can it be?
Okay, so when I am holding in the clutch I can feel a pulsing feeling going though the clutch pedal. It is kinda like someone is just lightly tapping on it from behind the firewall. Anyone have any ideas or suggestions? It's a sr w/act stage 2 clutch. I have a SS clutch line, but have not installed it yet. Should I wait, or install and see if that clears it up? Any help would be appreciated. Thanks.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
Old 01-25-2006, 08:32 AM   #2
g6civcx
g6civcx's Avatar
I have no idea what it is, but if you're doing clutch line, check this out: http://www.zeroyon.com/index/content/view/32/47/
Old 01-25-2006, 09:00 AM   #3
Shawn_of_the_Dead
sweet, thanks man. I appreciate it, that will come in handy.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Old 01-25-2006, 01:19 PM   #4
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
My first guess would be a bad TO bearing...
allmotorKA is offline   Reply With Quote
Old 01-25-2006, 02:29 PM   #5
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
I'm curious about this to as I've been getting that lately as well... Hmmm...
upSLIDEdown is offline   Reply With Quote
Old 01-25-2006, 07:00 PM   #6
aznpoopy
aznpoopy's Avatar
bad noise + weird vibration is typically a t/o bearing
when its bad you can feel it on the pedal, the steering wheel and the shifter... or even through the seat.
Old 01-26-2006, 12:12 PM   #7
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
i had a thread on this recently... i could FEEL mine clanking... i raised my car and it is coming from the transmission... but it stays constant with acceleration... and dissapears mostly with the clutch pressed down...
Sorry im not trying to thread jack... but im just thinking maybe its the same problem and we could both get it solved at once.
heres a link to the thread : http://www.zilvia.net/f/showthread.php?t=99745
i have been told that it could be my input shaft bearing (which i figured in the first place.)
s13silady is offline   Reply With Quote
Old 01-26-2006, 12:33 PM   #8
aznpoopy
aznpoopy's Avatar
yeah that's a different problem then the one here...
there's a big difference between hearing a noise with the pedal up vs. hearing a noise with the pedal down. its the difference between something wrong with the clutch system (tob) vs. something wrong with your actual transmission (input shaft bearings... maybe other internal bearings in the tranny).
Old 01-26-2006, 04:04 PM   #9
s13silady
s13silady's Avatar
so would it be the tranny if there is sound when the clutch pedal is not being pressed?
Old 01-27-2006, 12:02 AM   #10
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
my GF g35 does that and hers is brand new.
jdm538 is offline   Reply With Quote
Old 01-27-2006, 07:45 AM   #11
Lith
Lith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enough
Send a message via ICQ to Lith Send a message via AIM to Lith Send a message via MSN to Lith Send a message via Yahoo to Lith
I think your best bet is to pull the transmission out and to check the throwout bearing, clutch disk & pressure plate.. my guess is that it's the TO as well.
Lith is offline   Reply With Quote
Old 01-27-2006, 01:39 PM   #12
Shawn_of_the_Dead
alright guys, I dont have a noise...just can feel a light tapping feeling through the pedal. I can only feel it when it is pressed down. No noise is present right now...will pull it out and check the TOB. Thanks guys
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Old 02-02-2006, 08:11 PM   #13
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
it could be the pressure plate, or the bolts holding it down.
NIK90s13 is offline   Reply With Quote
Old 02-02-2006, 08:36 PM   #14
Phlip
Yes, I look like that
Phlip's Avatar
^^^ Agreed, I have had a similar clutch issue 2 times... It was the pressure plate when it happened to me the first time and that little "fork" thing holding the TOB the second.
Weirdo
And I write too!
Old 02-02-2006, 08:58 PM   #15
aznpoopy
aznpoopy's Avatar
i don't want to generalize too much, but
basically when the clutch pedal is not being pressed and the shifter is in neutral, your drivetrain is engaged. your tranny internals are spinning with the engine. so if you hear a noise, there is a strong possibility it is internal to the transmission.
usually it means a bad input shaft bearing.
Old 02-03-2006, 08:06 AM   #16
tunedis95
tunedis95 is an unknown quantity at this point
i have the exact problem....i had taken my motor out of my car to do a RHD swap and when i put my motor back in it started having this pulsing effect...i didnt even touch the engine or tranny besides just removing them from the car...?????
tunedis95 is offline   Reply With Quote
Old 02-03-2006, 09:33 AM   #17
NIK90s13
NIK90s13's Avatar
my t/o bering is going out as we speek, it makes noise in nutral without the pedal pressed,(going to change it with motor swap) but it doesnt serge the pedal. it may be the input shaft. I'd check the pressure plate, t/o bering first. cheaper to start with
Old 02-03-2006, 09:50 AM   #18
AuburnRyan
AuburnRyan is an unknown quantity at this point
I have the same apparent TOB issue. Mine rattles (noise and feel thourgh pedal) like hell when I get on it, developed suddenly after a quick shift one day after a year of my Spec Stge 2 in the car.
So how long can I ignore this without causing further damage- and what damage am I doing?
Also - I heard OE Nissan TO Bearing is best, right? even to use with aftermarket clutch?
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 02-03-2006, 01:57 PM   #19
NIK90s13
NIK90s13's Avatar
As far as how long a bad t/o bering will last, that is relitave. Mine is a couple of months. I do'nt like it, but the swap is close and I want to wait if it will last that long.
As for what dammage it will cause, if it goes to pieces, your pedal will not work, it might messup the fork that holds the t/o bering.
Old 02-03-2006, 03:43 PM   #20
aznpoopy
aznpoopy's Avatar
i drove on a bad one for 2 years.
you could break a tooth on the pressure plate, just to add to the list of potential 'make your car undriveable' problems it could cause.
