Old 02-20-2006, 06:29 AM   #1
Catdu
Catdu's Avatar
Catdu is an unknown quantity at this point
Lightbulb Signal Light Problem
I've been having problems with my signal lights recently and now its not working. My signals are not working, and also are my hazards. I checked the bulbs, they seem to be good. This happened after i left my turn signal on for about 5-10 seconds, and usually if i leave it on for that long or longer the blinker starts to fade and sometimes the fuse blows. I dont know whats wrong with it. Could it be wiring? I haven't touched any wires recently. argh! my hand is hurting from these hand signals! Any help would be nice guys. Thanks!
Catdu is offline   Reply With Quote
Old 02-20-2006, 07:53 AM   #2
g6civcx
g6civcx's Avatar
Usually when the fuse blows like that it's either a bad ground or a short-circuit somewhere. Check your engine harness that runs under the left front fender. Then start looking at grounds. Make sure you have the right fuse.
Then check the flasher relay. Sometimes they go bad.
Is this an S13 or S14?
Old 02-20-2006, 06:53 PM   #3
Catdu
Catdu's Avatar
yes its an S13, 1992 240SX. uhh, where can u find the flasher relay? is it near the fuse box? how do i know if its bad?
Old 02-20-2006, 07:03 PM   #4
g6civcx
g6civcx's Avatar
The FSM will show you its location. It's under the steering column. It has a 3-prong plug.
You test it by hooking up a 27W bulb and applying 12V power. This is detailed in the FSM as well.
Old 02-20-2006, 07:37 PM   #5
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
did you try changing the bulb? and if u did is it the right bulb? lol the book that has all the part numbers had 2 part numbers for the front and i bought the wrong one...lol and it made my lights go krzy.... took me forever to figure out it was the bulbs
IAM_SO_sLOw is offline   Reply With Quote
Old 02-24-2006, 10:22 PM   #6
Catdu
Catdu's Avatar
I never did change the bulb. I checked the bulbs though and it still looks good.
Well, Actually i found the flasher relay behind the climate control and the flasher is still good. I was thinking, even if the flasher was broken wouldnt it still light up? okay what should i check next its the weekend so ill reply faster .
Old 02-25-2006, 12:09 PM   #7
bigteddyted
bigteddyted's Avatar
bigteddyted can only hope to improve
something like that had happen to me before and it was because i had the wrong bulb type of bulkb in the wrong place. i think i had a brake bulb there instead of a regular. just double check everything is in the right place
bigteddyted is offline   Reply With Quote
Old 03-03-2006, 05:29 AM   #8
Catdu
Catdu's Avatar
i just checked my tail lights and it looks like theres water in there. somehow water is getting in there and could it affect the signal lights from turning on?
Old 03-03-2006, 08:22 AM   #9
g6civcx
g6civcx's Avatar
Yes, you need to pull out both taillights and apply new butyl seal. You can get it from Nissan dealers or at auto parts store.
Old 03-03-2006, 10:19 AM   #10
Ess14
Ess14 is an unknown quantity at this point
Flasher behind the climate control?
How are you checking the flasher? I'm not exactly sure what is checked when you connect it via the 3 prongs, the wires travelling to the resistor will receive power regardless but the resistor, spring wire, or contacts inside could be bad in different ways.
I would not imagine that it would be powered if the flasher is broken.
Ess14 is offline   Reply With Quote
Old 03-03-2006, 03:48 PM   #11
g6civcx
g6civcx's Avatar
Are you sure that's the flasher? It could be your blower vent mode relay. The flasher should have 3 prongs.
When you look at the prongs of the relay, the left one is (+), the right one is (-), and the top one goes to the bulb. You test it by hooking (+) to a +12V battery power source, hooking the (-) to ground, and hooking the top prong to a 27W (#1156 should do the trick) bulb and then hooking that bulb to ground.
If the relay is working, the bulb should be flashing like a turn signal. If not, the relay is broken.
This is outlined in the FSM. Make sure you check the FSM for the proper orientation so you don't wire the relay backward and damage it.
Old 03-04-2006, 01:45 AM   #12
koukidough
koukidough's Avatar
koukidough is an unknown quantity at this point
I had this problem for my s14. If all the fuses are okay then your problem maybe a bad hazard button/assembly. Yup its stupid how its designed, if the hazard button assembly is broken or not working correctly your signals will not work either. I bought a new OE button off of ebay for $20. Finally worked back. Seems like a piece of mechanical plastic was broken inside the button assembly. Then again this was a s14...
1997 Nissan S14 SE Redtop SR20DET @12psi
1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD)
koukidough is offline   Reply With Quote
Old 03-04-2006, 07:29 AM   #13
BlackSunshine42
BlackSunshine42 is an unknown quantity at this point
Blowing fuses = short.
Check your lines.
Yes that water could be causing your short. get that shit out of your light and seal it.
BlackSunshine42 is offline   Reply With Quote
Old 03-16-2006, 01:57 AM   #14
Catdu
Catdu's Avatar
Okay, I just changed my tail lights, replaced the bulbs for the signals and tails. Okay, I haven't done that test yet. I can't find any relay under the steering column. anyone got a pic of it? Oh and is it a sign that the flasher is bad if the signals are on when i turn the parking lights on?
Old 03-16-2006, 10:43 AM   #15
g6civcx
g6civcx's Avatar
The car sounds like it has some wiring goofs. You need to spend some time with the FSM and go through the wiring. It's too hard to do this on the Internet because you don't understand how wiring works and the rest of us can't see the car.
I think you swapped the wiring around somehow. That's why your signal comes on with parking. Can't tell you what to do because you're not doing a good job describing your problem.
Maybe you should take a bunch of pictures so we know what's going on. It's hopeless at this point.
When you say it's working or not working, does it mean the bulb comes on but doesn't flash? Does it mean the bulb flashes but too quickly? What does not working mean to you?
Old 03-16-2006, 06:59 PM   #16
Catdu
Catdu's Avatar
By not working, I mean that they are not blinking when I signal.
Old 04-13-2006, 11:50 PM   #17
Catdu
Catdu's Avatar
I just found the flasher relay it was hidden somewhere under the steering column. I couldn't see it but I pressed the hazards on and off to hear the ticking sound and spotted behind a metal part with a screw. So I replaced it and now it's good to go. Thanks for the help.
