Old 02-08-2006, 11:53 PM   #1
nyquil
nyquil is on the path to ruinnyquil is on the path to ruin
Send a message via AIM to nyquil
powersteering Q
My s14 pump is about to crap out and my resivour is also leaking
So ive found a few s13 resivours, lines, and pumps. My only question is, are all s13 powersteering pieces of hardware interchangable with s14 ps hardware? any help is appreciated
nyquil is offline   Reply With Quote
Old 02-12-2006, 09:24 AM   #2
nyquil
bump bump bump
Old 02-12-2006, 10:16 AM   #3
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
pump is the same, some of the lines are the same, most can be interchanged anyways. the res is different, bolt pattern to strut tower isnt the same
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 02-12-2006, 10:45 AM   #4
Cashizslick
Cashizslick can only hope to improve
Isnt there also a difference in the way Dohc and Soch powersteering setups run??!?!
Cashizslick is offline   Reply With Quote
Old 02-12-2006, 10:47 AM   #5
ryan hagen
ryan hagen's Avatar
sohc pump is way differnt, you can only use a pump from a ka24de s13 or s14
Old 02-12-2006, 07:33 PM   #6
Irukandji
if its not too late, you can try using some Lucas Oil power steering fluid. I used it on mine and it stopped the leaking completely.... the bottle says it "renews" your rack and pinion. I'm usually skeptical with "Fix in a bottles" but Lucas Oil wins fo sho.
Old 02-22-2006, 06:28 PM   #7
jaae86
jaae86's Avatar
jaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enough
Send a message via AIM to jaae86
Can I use a KA power steering pump to replace my crapping out SR ps pump?
Jeff Andrade
myspace.com/jeffandcrisandrade
jaae86 is offline   Reply With Quote
