Old 02-28-2006, 06:25 PM   #1
BFT Earl
BFT Earl is an unknown quantity at this point
Blacktop cranking, wont start
my car has been sitting for about a month now due to knee surgery and a dead battery. got the battery replaced today and it cranks but wont start. tried searching but cant seem to find a solution. please help.
BFT Earl is offline   Reply With Quote
Old 02-28-2006, 06:51 PM   #2
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
Have you tried reading the ECU LED codes yet?
chibo is offline   Reply With Quote
Old 02-28-2006, 06:51 PM   #3
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
Timing or CAS problem???
My old car did the same thing after it sat for a few months once...eventually started up just fine though.
mRclARK1 is offline   Reply With Quote
Old 03-01-2006, 03:43 AM   #4
BFT Earl
I haven't tried reading ECU codes yet. is it possible that my timing could be off or my CAS could go bad from just sitting there for about a month? i checked FPR gauge and it's still getting fuel when its cranking and i can smell gas as well, havent checked the spark plugs for spark yet..wont turn over when i try jumping it either
Old 03-01-2006, 03:57 AM   #5
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
i would check the timing, a friend of mine trouble shooted everything and it wounded up just being the timing.
jdm538 is offline   Reply With Quote
Old 03-20-2006, 04:31 PM   #6
BFT Earl
I finally had time to check the spark on the car and it's not getting any spark. Replaced the spark plugs and still no spark. Replaced the ignitor chip and still no spark. What could be some other causes that could prevent me from getting spark? I have a code E5 ecu (no LED so I can't read the codes) and I took a look at the board, seems to be ok, also my SAFC still works when I am cranking my car, which leads me to believe my ecu is ok. Any help would be appreciated, I really need to get this car started by next week. Thanks.
Old 03-20-2006, 07:19 PM   #7
smithers584
smithers584 is an unknown quantity at this point
check voltage to ignitor. a bad ground on the harness for the coilpacks could cause it, it grounds to the head back by the firewall. there is also a ignition coil relay that you could check for 12v to (between pins 1 and 2) and if its there then maybe the relay is stuck.
smithers584 is offline   Reply With Quote
Old 03-21-2006, 07:23 AM   #8
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
if the car cranked but didnt start sounds like timing thats what my sr did when i first got the swap done and i had a bad mafs.
rotation3x is offline   Reply With Quote
Old 03-21-2006, 08:39 AM   #9
BFT Earl
would my timing be bad from just sitting in the garage and could timing issues prevent spark? my car ran without problems for over a year up until i let it sit for a couple of months.
