![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Size of SR T25 banjo fittings?
I have no water lines for my turbo (SR T25)/engine (CA18DET) so I need to make some. Thing is, I don't know the fitting size on the turbo itself. I see that I can get some Earls banjo fittings, but I just don't know what size to order. Either that or I can make some nice push-loc fittings. Either way, I still need to find out the size! Anyone?
![]() Join Date: Apr 2004
For all SR:
* Water inlet on engine - 14mm x 1.5 * Water inlet on turbo - 14mm x 1.5 * Water outlet on turbo - 14mm x 1.5 For S13 SR: * Water outlet on engine - 3/8" clamp on For S14/S15 SR: * Water outlet on upper radiator hose water outlet - 14mm x 1.5 If you have an S13 SR, you can get the S14/S15 water outlet and return water there. Then you can plug the return line near the firewall. Taka Motorsports will make your life easy by supplying you a plug and play kit. |
