Old 03-08-2006, 05:22 PM   #1
Miami240z
Miami240z's Avatar
Miami240z is an unknown quantity at this point
Exclamation S13 Brake question from a fool.
I put on new pads but the piston was out too far. I tried to turn it to get it to retract but it wouldnt go back. While turning it the cup that sits in the seal bursts out and brake fluid comes pouring out. I get the cup back in and it goes all the way back. I knew I had fucked up so i try the brakes and they dont work at all. I knew they wouldnt work because of something to do with fluid but I dont know how to go about fixing it. Any help would be great.
Miami240z is offline   Reply With Quote
Old 03-08-2006, 05:43 PM   #2
VIPCefiro
VIPCefiro is making a name for him/her selfVIPCefiro is making a name for him/her self
mmm.. did you bleed the brakes?
VIPCefiro is offline   Reply With Quote
Old 03-08-2006, 06:29 PM   #3
Miami240z
Miami240z's Avatar
Nope. Had planned on just putting new pads in with dealing with any liquid but the cup popped out and it came pouring out.
Old 03-08-2006, 06:36 PM   #4
projectRDM
projectRDM's Avatar
If the piston came completely out, put it back in and bleed the brakes.
If the seal was damaged and it's still leaking, rebuild/replace the caliper.
Old 03-09-2006, 09:45 AM   #5
Miami240z
Miami240z's Avatar
I just had to post this before my friends got here to help. I knew my front brakes werent working but i knew my e-brake did. Went to change the rear left caliper thinking the other caliper would stay tight. I was wrong. Car rolls back off the jack lands in the middle of my foot. Just thought id add that cuz im not in a good mood right now.
Old 03-09-2006, 10:01 AM   #6
aznpoopy
aznpoopy's Avatar
next time, you can open the bleeder screw to relieve hydraulic pressure as you turn in the piston. just be prepared to make a mess. and don't forget to add fluid as you bleed, because your fluid will be low after doing this.
