Old 03-19-2006, 07:56 AM   #1
Zesty
Zesty is an unknown quantity at this point
Power mirror question? S13
Ok, probably dumb but I have to ask to know. Sorry.
I have an S13 that has no power mirrors. When taking apart my console, I noticed that there is a little harness along with the one for the cigarette lighter, and I assume this can only be for the power mirrors.
What I'm wondering is, even though my car DOES NOT have power mirrors/windows, does it still have the harness and wiring for it? Like, could I just get that power-mirror control, hook up the harness and pop it in my console, and I could have power mirrors?
Is this harness even for the power mirrors? And if it is, does my car have the wiring for the power mirrors, even though it wasn't factory equipped with them?
Zesty is offline   Reply With Quote
Old 03-19-2006, 07:02 PM   #2
Zesty
anyone? I tried searching and couldn't find anything related.
Old 03-20-2006, 04:45 AM   #3
Spec7
Spec7's Avatar
Spec7 is an unknown quantity at this point
I believe the power mirror harness is indeed what you have found, I have the same on my parts chassis that does not have power mirrors. My driver has power mirrors and I use that same harness for my control switch.
You could probably have power mirrors as long as you installed the power mirrors along with the switch.
No expert on this, just my presumption.
Not enough hours in the day to be nice all the time.
Spec7 is offline   Reply With Quote
Old 03-20-2006, 09:14 AM   #4
projectRDM
projectRDM's Avatar
It's not prewired. The plug you found should be a 6pin, that's for the automatic transmission shifter illumination. All 5spd cars are wired for that. The mirror plug is larger with about 10 pins.
The doors are not wired either, base models have wiring for the key latch and the speaker, nothing else.
Old 03-20-2006, 10:13 AM   #5
Zesty
^Well damn! Not the answer I was looking for, but I feel better KNOWING. Thanks a bunch.
Old 03-21-2006, 01:31 PM   #6
driftertim
driftertim's Avatar
driftertim is a well-known jackass
Send a message via AIM to driftertim Send a message via MSN to driftertim
Kinda Related to this, I have the North American S13 I have the power mirrors but I'd also like to have the JDM Power folding mirrors. Id there a relay that I need and can I jimmy rig something from radio shack to work arround it. If anyone has a wiring diagram or has insight on this Id appreciate it.
Cheers
-Tim
driftertim is offline   Reply With Quote
Old 03-21-2006, 01:44 PM   #7
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
Cheers
-Tim
All you need are the mirrors, the jap switch thingy, and some wire. You will need to run 2 extra wires to each mirror, thats it. Not to hard.
Slip&Sliden 240 is offline   Reply With Quote
